Question about HP Pavilion Media Center TV m7330n (ER101AA) PC Desktop
Hp pavilion m7330n motherboard issue
My media center edition m7330n broke down about a month ago. the system wouldn't boot up (i got a disk error at startup). i paid a guy $400 to fix it. he told me i needed a new motherboard, which he installed and dropped off at my house. when i turned on the computer i had no sound, no microphone, the dvd drive wasn't there to burn dvd, my memory card reader wouldn't work...
after several sessions with this guy the computer still does not operate correctly. he told me that the problem is the new motherboard isn't compatible with the system. he said i would need to reinstall the operating system and all my programs. i could have bought a new computer for the cost and headache this has caused me. what went wrong? did he not put the correct motherboard in? my media center won't open, it crashes, my dvd drive won't burn, etc etc. it tells me that my video card is i\ncompatible also. He said he also installed a new power supply. now i am out $400 and still cannot use my computer...
  • 1 more comment
  • waltz123 Jul 24, 2008
    My wife's HP m7330n quit two days ago with the same "system won't boot" problem. Additionally, the display was "wavy". I tried a different monitor and the wavy problem persisted. The waviness was not uniform. It would slowly change over time.
    Back to the hard disk. Rebooting and attempting to (F10) a recover gets no further than the enabled boot screen. I can get to the BIOS. Reboot several times and the original hard disk is not usually listed. I tried rebooting with a Knoppix Linux disk in the DVD drive. The machine boots. Knoppix is designed to do just this. But the drive may or may not be seen. I have taken the drive, a 250 GB SATA, and added it to another machine and have that machine start up on it. This same drive as a secondary, I can get to the file system and have backed up all the interesting files. (Lucky us!)
    Summary: Wavy display. The drive is openable on another non-HP computer. Is it the motherboard? The HP parts web site no longer has in stock the motherboard. Any suggestions for other tests?
    Your help is much appreciated! Thanks!
  • Anonymous Oct 04, 2008
    wave in the screen display,rarely boots all the way up
    disabled on board video add a pci card now hard drive never boots new power supply
    new HD wont see it take out PCI card then HD boots new PCI video card
    more of the same
    now looking to reset bios on main board or upgrade
    good luck with your just a peice of full on ****
    any other sugestions
  • Raahee Jan 12, 2009
    So finally, is the cause or problem with the motherboard or something else? My computer started having the same problem a couple of days ago. Thanks,
The system in question requires motherboard model ms-7184 and can be found on ebay for less than $100.  If your repair guy used a different motherboard you will get the issues described and need to reinstall the OS.  It is impracticle to put any more than $200 in most desktop computers more than 2 years old, your repair guy should have advised you of this straight off.  Find a new person to take your equipment.
Posted on Sep 08, 2008
HP Pavilion m7330n: Possible corrupt bios, solutions anyone?
what OS? is this XP? with SP3 or not? needs it. if XP.
you never need to delete old hdd, drivers ever.
reg booster?
would not reboot. the HDD fails>?
its not really BIOS, corruption at all,
if the CMOS battery is above 2.9v then no corruptions happen.!
the ROM part will not corrupt but the ram part can , easy, Battery.
check this battery any time bios forgets things this battery is the
no forget feature (CMOS NVRAM battery backup)
Bios can boot to any dvd, or cd, if you plug it and and select it.
BIos can boot the HDD, or SSD, or USB stick. and more, F9 key?
never use reg booster, avoid it like the plague,
any reg modifying programs are nothing but trouble. !!!
m7330n circa 2005. a desk top (or media center) Athlon 64 X2
so what DVD are you installing,
Sata, or PATA
tell what you have and why you need and adaptor,(btw i have them all here, from you name it ,to what eva.)
the HDD is SATA.
but what is the DVD jacked into?
dvd drives come in;
PATA
SATA
USB
what is yours?
May 06, 2017 | HP Pavilion Media Center TV m7330n...
At boot-up, HP Digital Media Archive pops up for no apparent reason. Cannot find a way to prevent it.
Have you tried using msconfig to see if it is listed under startup programs? If it is listed you can uncheck it and it will no longer load at start up.
Aug 13, 2011 | HP Pavilion Media Center TV m7330n...
I have an HP Media Center PC m7330n. It recently was infected with a host of viruses and rootkits. I eliminated all the viruses and rootkits with a battery of anti-virus programs. Everything works as...
You might want to try to go to the device manager and go to the Universal Serial Bus controllers
Try to uninstall everything and restart the computer.
See if that will let the computer recognise the USB ports.
If that does not work, you might want to reinstall the chipset drivers of your motherboard.
Hope this works for you.
Jun 21, 2011 | HP Pavilion Media Center TV m7330n...
Hi .... I tried to plug in an external USB drive that had previoulsy been attached to my PVR. Runnign Win 7 Ultimate. Got message about an INITIO driver being installed and then the drive access light...
is the usb drive still attached? if so, unplug it from the pc and see if this fixes the boot issue. If so, you most likely have your bios set up to boot from usb first. You can either change this order or remove the usb drive every time you reboot.
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Open link in new incognito window
  • Download file
  • Copy link address
  • Edit PDF File on PDFescape.com
Feb 26, 2011 | HP GX612AA Pavilion Media Center M8330F...
My HP Media Center m7330n won't power up... The fan comes on but will not boot.. The LED power light blinks at 3 second intervals from blue to yellow/orange.. What is the diagnosis...
You have to check with your RAM sir, if you know to remove the side cover of your CPU(tower) there will be a green colored chip fixed in vertical position in the motherboard if remove it and then fix it properly means you will get the display in yur screen.i will show you the RAM picture2f70f69.jpg
Oct 29, 2009 | HP Pavilion Media Center TV m7330n...
My HP media center edition m7330n desktop will not power up (won`t stay on), The power button light flashes every 2 seconds from blue to orange & no power at usb ports. Any advise on what went bad or...
Before doing anything try to get the following tested,Processor,Power supply,Memory,also remove any cards installed including modem.Look for physical damage(ie) Brown substance coming from capacitors on board all capacitors should be flat on top if they show rounding or a hump over the top the MotherBoard needs rplacing!
Aug 08, 2009 | HP Pavilion Media Center TV m7330n...
Same problem m7330n motherboard packed up !
I really don't like HP. They make **** and will always make ****.
It sounds to me the motherboard is on it's way out.
Sorry, but getting another computer seems to be the only viable option.
I think it's best you shop around for a good computer for your needs.
I can't recommend one to you as I build my own computers for myself and customers.
Jul 11, 2009 | HP Pavilion Media Center TV m7330n...
Problem with window media center installation ?
Hi there
Even if you changed the computers name chances are that won't sort the problem, it sounds to me like a bad install in the first place. I would go with the re-install of the operating system.
You can call your computer whatever you want most people use their name, for example "yourname-PC".
Make sure that the disk and the lens is clean.
Good luck and thanks for using Fixya!!!
Feb 13, 2009 | HP Pavilion Media Center a1330n - AMD...
Wireless bottom
the wireless setup is in you remote
Aug 30, 2008 | HP Pavilion Media Center TV m7330n...
New Motherboard
have you check your bios configuration? if no please do.
Nov 01, 2007 | HP Pavilion Media Center TV m7330n...
HP Pavilion Media Center TV m7330n (ER101AA) PC Desktop Logo
1,910 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
