Question about Xerox Phaser 8550DX Laser Printer
The printer doesn't want to print
I have a problem that seems so simple but yet it still does not work. The screen says:
"Add black ink"
"Press ?"
However, there are enough inks in the cartridge for all for trays. When I power cycle it, it sounded like the printer is trying to load (or pick up) but can't. I can hear a lot of clicking (moving parts) but nothing. Is there an actual mechanical problem at work here?
Comments really appreciated. Thanks..=)
  • sdinh Jun 27, 2008
    For the comments just posted earlier, I am referring to the Xerox Phaser 8550.
  • sdinh Jun 30, 2008
    Thanks...I will check that out...greatly appreciated..
  • 2,072 Answers
Your ink stick may be cracked not actuating the switch in the ink loader.
If the improper ink stick was loaded the bottom of it would have a different shape and not actuate the switch. Try taking a screw and twisting it into the black sticks and removing and reloading them.
You may have a bad ink loader, but I suspect more a misshapen stick or on that is slightly stuck and not advancing properly.
But, the possibility of a bad ink loader , where you load the sticks, is still there.
Posted on Jun 28, 2008
The black ink has stopped printing. Put in two different new cartridges and that doesn't seem to be the problem. It was first noticed when photos were printing out funny even after changing the color...
Make sure you are inserting genuine Lexmark cartridges.
Try to clean the cartridge nozzles. Refer to the steps below:
Cleaning the Print Cartridge Nozzles:
1. Open the Lexmark Solution Center. Click Start > Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix horizontal streaks.
3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
4. Print the document again to verify that print quality has improved.
Using the control panel
1. Press Menu.
2. Press the down arrow button until you highlight Clean Cartridge.
3. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Oct 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
My x5495 black and color cartridges are not printing. they have ink in them, but will not print. have cleaned cartridges and still will not work.
Try this approach:
  1. When you're on Copy mode, press the Menu button on the printer operator panel.
  2. Press left/right button until Tools is selected on the screen.
  3. Press check.
  4. Choose Maintenance.
  5. Press left/right button until Clean Cartridges is selected on the screen.
  6. Press check.
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them. After the page is printed, try to print your document/file again to verify if problem is resolved.
You may also try to reseat the cartridges by removing both cartridges from your printer > close the printer cover > unplug/re-plug the printer into the power source to reset it > when the printer turns on, firmly re-insert the cartridges. Try to print again.
If that doesn't help, try to insert different known working cartridges.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 29, 2011 | Lexmark X5150 All-In-One InkJet Printer
Our Lexmark Prospect Pro205 has sufficient ink in the black cartridge. The error message says there is interference with the black ink cartridge. Black ink does not print, but color inks print.
Your cartridge may need to cleaned. On the printer operator panel, press Setup button -> Maintenance -> Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
If that doesn't help, your printer probably needs to be updated. The firmware update, available at, will help fix print quality issues.
May 02, 2011 | Lexmark Prospect Pro205 Wireless...
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
Maybe you can try to rest the black ink level 1st. To reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Jan 14, 2009 | Lexmark X2500 All-In-One Printer
New ink cartrage
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Do not do any other operations until print head deep cleaning is completed.
    Ifthe printed result does not improve even after doing print head deepcleaning, turn off the printer. Then, after 24 hours or later, do printhead deep cleaning again. (After a given time interval, ink coulddissolve itself, resulting in ink unclogging.
Jan 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Full black ink cartridge - but says there is no black ink
To run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
Wicking the Cartridge
  1. Ensure the printer is powered on.
  2. Lift the scanner unit.
  3. Open the cartridge latches and remove the cartridges from the carrier
  4. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back
Cleaning the Contacts
  1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
  2. Using a clean dry cloth, wipe the contacts in the direction, so that no dust or other contaminants are visible.
  3. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
  4. Replace the cartridges in the carrier and close the scanner unit.
  5. Print the document again.
  6. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
Verify the Ink Cartridges Are Installed in the Proper Slot
  1. Remove the ink cartridges from the printer.
  2. Read the label on the side of both cartridges to identify which is color and which is black.
  3. Install the black cartridge in the slot on the left and the color cartridge in the slot on the right
  4. Close the ink cartridge lids and make sure they lock in place.
I hope it helps!!!
Nov 18, 2008 | Dell 924 All-in-One InkJet Printer
Color ink cartridge out. Won't let me print in black only?
Do this, press and hold the "Stop" button on the printer for 10 seconds that should clear the fault set by the empty ink cartridge.
Jul 21, 2017 | Canon PIXMA iP1800 InkJet Photo Printer
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Xerox Phaser  8550DX Laser Printer Logo
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
