Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi Projection TV model 53UWX10B
There is a wave on top left picture, green and red halos on all objects on left side the picture magic button displays red x all out of alignment and won't go back after pushing the picture magic button
Hi,I just had this problem on july 1 2008.I called hitachi at 1-800-448-2244 on july 4th.They gave me a phone number for my area,They had a repairman in my area.They sent him over on the same day.It took me about an hour,and it works great.The tv is brighter than before much better.The cost of the repair was 406.80.The service call $60.00 the repaired part $ 300.00.The GST $18.00,PST $ 28.80.Having a TV that works priceless.Good luck I hope it helps.
Posted on Jul 07, 2008
I SEE DOUBLE THE PICTURE AT THE TOP LEFT IS WAVEY
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 28, 2010 | Hitachi 53UWX10B 53" Rear Projection...
HITACHI ULTRAVISON REAR PROJECTION TV HAS 3 OF EVERYTHING. IS IT WORTH FIXING?
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Seeing double
These sets have several common problems which are listed below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV may have one or more of the following symptoms....
You can see some more examples and find the fix here...
Mar 31, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Magic focus runs half way & stops &showes a #4 ? one side of a face has a green outline the other side red
You may have a burned out convergence chip. But first, if you haven't already, you can try service mode to adjust convergence. Press the Magic Focusbutton, and then press it again to stop it, and then press the Statusbutton on your remote. Here's a link to the manual convergence procedure (scroll down). Warning-- When I did this the set got stuck in one of the adjustment screens. I had to remove the bottom front panel of the TV to reach the "little blue" reset button to get back a TV picture. But I think this is worth trying before replacing parts.
Mar 02, 2010 | Hitachi 53UWX10B 53" Rear Projection...
THE PICTURE IS GHOSTING AT THE TOP & BOTTOM OF THE SCREEN. THERE
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 28, 2009 | Hitachi 46F500 46" Rear Projection...
I get a split up of red and green in a wave at top of screen
The convergence ICs and resistors are the most likely things to cause that. You can get the convergence repair kit for the DP14G hitachi( 53UXX10B) at the following link which contains the parts and instructions.
http://www.tvrepairkits.net/
Jul 11, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Can't set red convergence on 65" Hitachi
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Dec 24, 2008 | Hitachi Director's Series 65XWX20B 65"...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Projection tv
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 17, 2008 | Hitachi 43F300 43" Rear Projection...
Red Halo Hitachi 53FDX20B (2002) model year
You can get the replacement Convergence ICs at this website I am posting. Just order the same STK numbers that are on your Convergence ICs. They provide instalation instructions and free on line tech support with every purchase. Heres the link.
http://servicemanuals.vstore.ca/
Apr 11, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
65 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
