My Xerox XRX-8X paper shredder plastic drive gear has a broken tooth. Shredder teeth will not turn continuously as a result. How can I purchase a new plastic gear?
  • k4djg Sep 03, 2008
    Main two step gear has inner teeth (smaller gear) stripped. I need help locating a replacement gear.
  • NAVYFNP Nov 30, 2008
    WHERE DO I GET A DRIVE GEAR FOR MY XEROX PAPER SHREADER
    CHEAP.
WHERE DO I GET A DRIVE GEAR FOR MY XRX-8X PAPER SHREADER CHEAP.
Posted on Sep 03, 2009
My paper shredder will not shred or grab the paper?
If the motor is spinning, it's probable broken teeth on the drive gear. The drive gears are usually the first thing to break on a shredder.
If the motor doesn't spin. The paper may be clogged in the grinder claws. You may have to turn the shredder over (after you remove the power cable from the wall outlet). Then remove the papers from underneath.
Hope this helps.
Feb 28, 2015 | Shredder Office Equipment & Supplies
My shredder has the sound like it is working, but it is not shredding.
From your description, it sounds like when you insert the paper the motor turns on, but the paper is not pulled into the shredder, indicating the two shredder cylinders are not turning. The most likely cause of this is a stripped (missing teeth) main nylon gear. These can be replaced but require some effort.
Apr 17, 2014 | Royal Office Equipment & Supplies
Ativa shredder manual
Are the shredder blades going around? most shredders have guides that guide the paper between to shredder gears or teeth. these guides are usually made of plastic and breake. First step is to see if the shredder gears or teeth ar going around.....
Sep 23, 2013 | Office Equipment & Supplies
Broken cog spool - replacement
Hi you should buy new shredder because you will not get the plastic part easily and usually they do not be replace.
Jul 28, 2010 | Fellowes P57Cs Shredder
Repair parts for a royal paper shredder
I'm just trying to update this answer the number for parts is incorrect and I spent over 2 hours on hold without result. I then called the product support number and was re-directed to the sales number. When I called it I spoke to a very helpful rep who listened to my story and immediately transferred me to parts where the service technician was EXTREMELY helpful in identifying the part required and then taking an order to get the part shipped. The cost of the plastic gear was $3.16 I didn't ask what the shipping was...
Sales phone number: (888) 261-4555
web address: http://www.royalsupplies.com/contact-us.html
Jul 09, 2010 | Royal 15MX Shredder
The aparatus that pulls the paper into the shredder doesn't work
Check to see if cutting shafts are turning in either forward or reverse operation. If not and you can hear the motor running the take off cover and check plastic gear drive train...probably something broken in there.
May 25, 2010 | Aurora Electronics AS662C Shredder
XRX-8X shredder is jammed. Can I safely open
Soak the clog with soapy water,,,,seriously
Sep 25, 2009 | Office Equipment & Supplies
Where do I get a gear to turn the shredder
Her
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
e is my response
Mar 22, 2009 | Tech Solution TS-4500 Shredder
Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Jan 19, 2009 | Intimus 385 se Shredder
1,376 people viewed this question
k24674
jasbo
jasbo
