Question about Dell Dimension 4600 PC Desktop
Computer to tv
What do I need to connect my desktop computer to my tv?
  • 3,940 Answers
You'll need a video card that has an S-Video out port and a TV that has S-Video in. Generally, adapters and converters don't work well.
Once connected with an S-Video cable, you should be good to go.
Posted on Jun 27, 2008
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
Dell inspiron 1520 how do i connect to my tv
The Dell has a VGA port 15 pin DSub connector and if your TV has a 15 pin viseo connector the you need a 15 pin video cable. Check the connectors on the Dell and TV so you get the correct connectors. You will need to select the computer input on your TV so it can display the Dell computer video images.
Apr 17, 2012 | Dell XPS One All-in-One TV Desktop with...
What type of cable do I need to connect my HP desktop computer to my TV set so that I can watch web content on a bigger screen?
You can connect the video with an SVGA cable. If you want the sound to come through the TV easiest solution is to get an HDMI cable, assuming your laptop has the output for it and your tv has the input for it. It's a trapezoid port if you have it.
May 05, 2011 | HP Desktop Computers - Hewlett-Packard...
How do i connect my acer z5600 to my hd tv
Inorder to connect computer to an LCD TV, you need a HDMI or DVI port on both TV and computer. You will also need a cable for them. You can check on the back of the computer and
TV for HDMI port, it looks similar to USB port. If it is there, then you may need a HDMI cable and you can connect TV and computer through it.
Thanks and regards,
Dec 18, 2010 | Acer Aspire Z5600 PC Desktop
How do i connect a tv to my gateway computer
Do you have an HDMI port in your computer? If you have, then it is easy to connect your computer to your tv making your tv an extended monitor in watching high definition audio and video.
If you want to connect your tv to your computer and watch tv shows, you need to install a TV Tuner Card in your cpu through a PCI or PCIE Card. Once installed, at the back of your cpu, you will have a co-axial port or a compatible port to connect your tv to your CPU.
Feb 09, 2010 | Gateway GM5472 PC Desktop
How to hook up your computer to your tv
You will need a TV tuner or Video card with a built in TV tuner.
Nov 20, 2009 | HP Pavilion m7580n PC Desktop
I have HP media center M1050E desktop. My question is there anyway to connect my desktop to my TV with the use of any wires to take advantage of internet programs. Please provide me the information with...
If you want to connect your TV and your desktop.
you need the AGP card or the TV tuner card. If you want the TV programs to be save then use a video capture card also.
Sep 27, 2009 | HP Pavilion Media Center a1330n - AMD...
Yah i have a dynex tv and a Asus desktop comp and my tv says no signal when i plug it in i dont know what the problem is
Is the dynex tv unit installed inside the ASUS desktop computer?
The TV receiver needs an antenna/aerial connected to the TV receiver to receive TV signals, without it you will get no or weak signal.
Have you connected an antenna/aerial to the Dynex TV unit?
Jul 22, 2009 | ASUS Computers & Internet
How to do
first of all all you need is to check if it has on s-video port. a port that connects your computer to tv and a cable for connecting to tv.when it is connected it will automatically change to tv view.
Apr 28, 2009 | HP Pavilion A6600F Pentium dual-core E2200...
You Need a VGA to DVI Connector and a dvi cable which connect at the back of the tv.
you need to connect the VGA Port(Blue Colour) with VGA to DVI connector and then Connect DVI cable and Connect your computer.
Jul 14, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
93 people viewed this question
Alun Cox
