Maytag front load washer mah8700a power dead clothes stuck inside!!
I need to open my washer asap!!!! My sons baseball uniforms are in there-playoffs tomorrow!!! Washer just died after cycle....cant open door. No power at all. plug is working though. is there a manual release handle on these? took out detergent tray..nothing under there. HELP!!!
  • 481 Answers
Take out he screws that are under the detergent tray door and remove the whole detergent tray assembly, there should be a plastic chord with a loop on the end; pull it hard to unlatch the door.
Posted on Jun 28, 2008
Error code ND cannot get door open -soggy clothes inside
The "nd" indicates "no drain" and would usually mean something is wrong with the drain pump.
I would suggest checking the drain pump for obstructions or if it hums or tries to run.
Most likely there is a piece of clothing in the pump or it's bad and needs to be replaced.
The wrong soap might cause excessive suds and create a drain problem.
The image below will help you remove the front panel to access the pump.
Jan 10, 2011 | Maytag MAH8700A Front Load Washer
The machine will "hang" with
Check the pump sump cleaner. Under the front panel at the bottom. DC means the door is still sensed as open . If it occurs more often may need new door lock switch
Oct 29, 2010 | Maytag MAH8700A Front Load Washer
Samsung WF337AARXAC - door locked
Here are some things you might try:
Jun 04, 2017 | Samsung WF337AA Front Load Washer
My washing machine is "eating" my clothes!
ck the plastic fins in basket for broken/sharp areas
May 28, 2008 | GE WBVH6240F Front Load Washer
No power at all
ok first if you look in the dispenser drawer may have to push the tab and remove the drawer there is like a yellow pull tab will unlock the door second if your sure their is power to the washer the look at the control panel for burned resistor on the control bd and let me know if your serial number ends in ga through gx or ja through jn
Jan 30, 2008 | Maytag MAH8700A Front Load Washer
Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Dec 08, 2007 | Maytag MAH8700A Front Load Washer
If you open up the dispenser tray on the top of the machine, there should be a red cord. This is the manual release for the door. All you have to do is pull this cord and the door opens. If the cord is missing, you will need to remove the top of the washer to get to the latch. I hope this helps you.
Jul 16, 2007 | Maytag MAH8700A Front Load Washer
My Maytag front loading washer does not fully rinse cloths MAH8700A. I purchased this washer about 6 months ago. I usually wash small loads but have noticed it doesnt matter what size load. When first...
Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
Feb 25, 2007 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
