Question about Gestetner C7435n Laser Printer
Lines on paper
I have a Gestetner C7521C and want to know if it might be the roller bar or something else.
    Guru:
  • 859 Answers
Its from your roller bar from toner build up. You need a special paper that's designed to clean your rollers off. That's the easier and quicker fix.
To clean up a laser printer that's leaving lines on paper do the following and should you get stuck post to us on fixya.com for some assistance.
Digging into the guts of your machine would clean it up too if you know how or are handy this way. And, maybe the only way if you've printed a lot of sheets and the inside of your printer is filled with toner dust. The dust comes off the paper itself and just gets inside and starts to blow around until you see what you're seeing. The good lasers are expensive and I take them in for annual servicing all the time.
Two things to be aware of though, you will want to do this outside or in a garage on a plastic sheet and wear gloves. The toner is static sensitive by design and it gets everywhere. You'll want a small vacuum with a clean bag you'll trash later, canned air, a 3/4 inch natural bristle (less than a buck type) paint brush and some lint free rags. All these things you'll have to dump when done as you'll get them saturated with toner and its best to trash them when done. I use an old Orek cannister vacuum outside and no bag to get better suction and the hose can be swapped easily on this vacuum with the exhaust to blow instead of going through cans of air.
Remove your toner cartridge carefully and place it in a bag and place it well aside.
Disassemble the unit in a layout order that will help you reassemble it later.
As you take each component out blow it off in an area away from disassembly area and downwind. Look for areas you can clean out further with your disposable brushes and then blow that area out too.
When you get to the rollers and have done the above sequence put a clean brush in alcohol and wipe down the rollers until they're clean. Once the rollers are done, you'll need another clean brush and soak the rollers down with clean water. The alcohol shrinks the rubber compound and the water will rehydrate them. This is pretty important as a roller that has shrunk from dry humid climate or cleaning the rollers will start to slip or worse one side will and the other won't and you'll have a paper jam.
Go through your entire unit this way and on reassembly you may want to look the gears over and see if the white lithium is pretty dark, if so clean those off by wiping and add new white lithium to them.
Be pretty careful putting the toner into place and make certain it is latched.
Once the unit is clean and reassembled just plug the unit it while your still in your clean up area and power on and then off. Do this a couple of times so the gearing seats itself. When you energize a printer fully, it goes through a power on self check, that will fail if you don't power on/off quickly a few times for the gears to seat themselves. Then let the system energize completely. You may get an error message, don't be too surprised, just look it up and see what needs to be done about it.
Once it energizes and powers up with no error messages other than you're not connected to a computer start feeding sheets out the printer until they come out clean.
You should be good to go at this point. With your computer off, connect to your computer and power up. If you have any trouble post your problem here at fixya.com
Regards,
Worldvet
Posted on Jun 27, 2008
Wrinkled creased paper
Check the fusing unit lower pressure roller and the pressure roller cleaning roller.Is dirty.
Apr 22, 2013 | Gestetner Office Equipment & Supplies
I have a Gestetner DSC224 copier/printer that has started to output poor copies and prints. Documents come out of he machine with horisontal blank/unprinted streaks across the papers - in my case mostly...
Watch the development stations to see if there are white lines that match. The stations are easily removed from the left side. If so, stir vigorously the station and manually turn the developing roller
May 30, 2011 | Gestetner Office Equipment & Supplies
Gestetner 428 colour photocopier: background effect all over
It's possible it could be the transfer cleaning unit, but it's more likely to be the fuser or the transfer belt itself. If the hot roller is old or dirty or the press roller isn't providing enough tension, all of the toner might not be getting fused to the paper.
If only one color were showing mottling, it would probably be the developer, but it's unlikely that all four developers went bad at the same time.
Jul 03, 2010 | Gestetner Copier
Paper will not feed Gestetner 5325
check the paper tray end stop ie the green tab that keeps the paper in the tray as these can come out or be moved.. when you load paper make sure the green tab is tight against the paper.. also the feed rollers might need replacing.. if you take the tray out and then look inside the opening to the right hand of the opening you will see some grey rollers or it may be one large roller this can be removed and cleaned.. the small type have a litle white clip holding in place.. if you have the large roller there is a plastic black lever towards the fron on the top right that has to be moved out to the front then you can remove the roller and clean..Good luck let me know if you need more info
Oct 19, 2009 | Gestetner Office Equipment & Supplies
Gestetner DSM635sp paper stuck error.The machine throws the error and then stops. there is no paper that is ever stuck. Thanks for your help.
Hello sir; There should have a paper stuck over the pick up roller that you can't see if you pull out the tray paper should be squeeze together. the solution way is replace paper pick-up roller.
Oct 01, 2009 | Gestetner Office Equipment & Supplies
Lexmark x83 does not pull paper through; what do I do?
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned.
Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
Next, follow the steps given below to perform the self-test:
1. Press the "Menu" button 10 times. It should then read "Maintenance" on the printer's display screen.
2. Press the "Select" button once. You should then see "Cartridges" displayed on the printer screen.
3. Press the "Right Arrow" button 3 times, which then brings you to the "Self-Test" option.
4. Press the "Select" button once. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues and we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Sep 30, 2009 | Lexmark X83 All-In-One InkJet Printer
Hi, Got a problem with Gestetner DSc38 document feeder. It will grab everything at once. Already changed the nessessary parts "Paper Pickup Roller, Separation Roller, Paper Feed Belt " still...
If you already changed out the separation roller and the pick-up roller and your still having the issue then logically it sounds like a paper problem where they may have got glue on the edge of the **** and they're all sticking together or on the separation roller there is usually a small clutch like mechanism that sits right next to the roller which may not be doing it's job anymore. Can't think of much more that it could be, hope this resolves your issue and if so, please mark as a fixya... Dan
Sep 24, 2008 | Gestetner Office Equipment & Supplies
Black lines on the back of the printer page
the rollers / guides the the underside of the paper touches
Sep 11, 2008 | Office Equipment & Supplies
Dsm651sp
Repalce the pick up rollers,paper feed rollers, seperation rollers of the trays which gives the pper jam
Oct 22, 2007 | Gestetner DSM 651 Copier
Gestetner C7435n Laser Printer Logo
67 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
