Question about E-Machines T2240 PC Desktop
Volume on computer very very low. I have setings on high but it is still practically inaudible. I have an hp pavilion computer with an hp monitor with built in speakers
  • Anonymous Sep 25, 2008
    no sound
  • JGalbs Feb 09, 2009
    my speakers are vary low but my settings are set on hi how do I fix It.
I have no audio on my computer a month ago i was deleting stuff
and i did something and now i have no audio
Posted on Dec 04, 2008
Sound dead. no PC stated no OS stated, XP?
sound dead,
no OS stated, is this XP:?
no PC stated, just a screen monitor F1903 (old)
to have sound , there is no need for modems or the internet for sound. ever.
I guess this is a desk top PC, yes some use external monitors on laptops for good reasons, (its bigger)
so cant tell what you have there but guess some PC desktop
is it a HP desktop, ?
my guess With select models, one set of Harmon Kardon speakers with a DC cable and a DC power adapter.
if that is what is connected?, (is it?) then the DC pack is not plugged in, the DC pack power the speaker amp, in the speaker box where ever it resides. has
no power applied there will be , no sound if true.
ive no idea at all what you have there,
you need to say or show photos.?
or ask a geek to fix it. (one who hates chickens)
Oct 19, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
My Korg c15s has a lot of grating staticky noises when played ....I'm told it cannot be repaired as Korg no longer makes parts for this model?
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
I hope this info helps a bit.
Aug 18, 2010 | Yamaha Full-Size Keyboard
Speakers don't Work on HP Pavilion f1903 desktop
Just match the color of the male and female on each end. Plug the audio cable (mini stereo phone plugs) to the PC audio line out (green miniphone jack) to the Powered speaker mini stereo phone audio line input jack (green color jack). You will have to set the volume controls of the speaker control knob and at the PC on screen volume control panel.
Mar 29, 2010 | HP Pavilion F1903 19" LCD Monitor
Low volume on my HP Pavilion dv6-1245
Open the audio panel (settings -> control panel -> Sounds and audio devices -> volume). Check that the volume slide is all the way to the right. Also, click on the "speaker volume" button and check it is all the way to the right
Mar 21, 2010 | HP Pavilion dv6000z Notebook
My HP Pavilion dv4 Notebook drops its FPS drastically when hot
Hello,if this is the first time that happens its OK but if every time you play or you stressed the CPU shutdowns or restarts the you should take it to a repair shop.You can download a program to monitor the temperatures to see if its a CPU or graphic cards overheating.As i can see your graphic card is low-mid range and on-board so don't stress it, putting high resolutions or high details and make it overheating and stress more your CPU.
Jan 31, 2010 | HP NB199UA Pavilion Notebook
HOW DO I TURN DOWN THE VOLUME? I DOTN SEE THE VOLUME BUTTON
This monitor has no volume. The volume is controlled by the computer connected to the monitor, and not controlling the monitor itself.
To regulate volume on computer, click on the small audio icon near to the clock, or locate the audio settings icon in control panel.
Jun 04, 2009 | HP Pavilion F1523 15" LCD Monitor
Low volume on HP Compaq FP 7317.
You can try using an audio enhancer. That can boost your audio volume a bit.
Check out: http://www.pcauthorities.com/multimedia/how-to-boost-laptop-audio
Works for PC's as well as laptops.
Jules
Jan 12, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Whereabouts and meaning of OSD
OSD stands for On Screen Display. You get to it by pressing the Menu button on the front of your monitor.
Here's a link to making adjustments...and unlocking the OSD:
HP f1703
Oct 18, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Volume problems
reset the default seting and it will take originality
Sep 29, 2008 | HP (PP036AA) Computer Speakers
E-Machines T2240 PC Desktop Logo
43 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
