Noisy air conditioner
The blower on the furnace is really noisy but no air is coming out of the vents.
    Novelist:
    Champion:
  • 230 Answers
Sounds like the motor shaft and/or blower wheel have broke. The best scenario is that the blower wheel has only become loose. Shut the unit off. If you are comfortable using tools then use your manual to show you how to remove the blower assembly. When it is out you will need to check the Allen screw that holds the wheel to the motor shaft. If you are lucky you can just align the screw with the flat side of the shaft and re tighten! If you have the unit out, it should be pretty obvious if there is any other physical damage. Make sure you can spin the unit freely without any other complications before re installing it. Good Luck!
Posted on Jun 27, 2008
Smell fumes like exhaust when furnace comes on
You really, really need to get your furnace checked by an HVAC (Heating, Ventilation and Air Conditioning) expert. Your furnace has a section where the fire heats tubes that air is blown across then out to your home to heat it. The air in your home and the air from the combustion process should never mix. If you smell exhaust, it's possible there is a breakdown in this part of the furnace and exhaust, which can include carbon monoxide, could be pulled into the air stream and be circulated in your home. Carbon monoxide can and will make you go to sleep and not wake up! Do not use the furnace until you get it checked.
Feb 08, 2013 | Goodman Furnace Draft Inducer Blower ...
A/c blower turns slow and makes puffing sound. bryant 80% avac system.little cold air from vents
Hello, replace the capacitor as when there are storms sometimes they can cause a voltage spike and damage the capacitor. The capcitor will be a round or oval metal looking can next to the motor. When the blower motor runs slow the coil can start to freeze due to lack of airflow and this is why little air is coming out of the vents. If the capacitor does solve the problem then the motor will have to be replaced.
Jul 01, 2012 | Bryant Heating & Cooling
Gas pack will come on. Thermostat is working. No heat will come out of the vents. ???
Sounds like a blower relay or a blower motor... you will have to check for power to the motor to be sure...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 15, 2011 | Heating & Cooling
It's a brand new unit but it blows air so hard and makes so much noise. Can the flow the adjusted down?
is the fan outside too noisy,if so there is no way to change the speed of this fan,the blower motor in the furnace can be adjusted,either by adjusting the centrifugal pulley on the motor shaft or electrically or installing a different squirrel cage fan on the furnace blower
Aug 22, 2010 | Goodman CLQ36AR49 Air Conditioner
Furnace blower won't stop running
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Jan 04, 2010 | Amana Comfort Zone 12M32PBEH Air...
Furnace blower motor vibration
Check for a loose set screw on the motor shaft for the blower wheel.
Check the blower wheel for a missing balance weight.
Check the blower wheel for a dust buildup in the blades.
Check the blower wheel for a broken fin blade.
Check the blower motor shaft for excessive play.(more than 1/4 inch of play).
Check mounting screws on the blower housing.
Jan 04, 2010 | Ruud Heating & Cooling
Air not blowing out of inside vents for my a/c
assuming you have a split system check the inside blower at the furnace. You also can check by putting the thermostat fan in the on position. When you are at the furnace look at the coil on top and make sure its not frozen.
Aug 09, 2009 | Heating & Cooling
Gas furnace continually running
Is the blower operating and are your air filters new
Jan 03, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace blower needs repair
Hi,may be your Fan motor shorted ,pls check the that lead wire of FM.
Regards,
Edgz
Feb 08, 2008 | Goodman CPLE24-1 Air Conditioner
Coleman furnace problem
Sometimes people replace the blower motors with a higher horse power. Has this motor ever been changed? I believe the original should be a GE motor
Nov 12, 2007 | Heating & Cooling
Heating & Cooling Logo
793 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
