Error code Our cash register wont allow us to punch anything in at all. Any time that you touch a key, the error sign appears as does the high pitch alarm. What is wrong? The batteries have been replaced.
  • Anonymous Apr 26, 2009
    I am getting error ER01 (registration) after programming the alpha entries on a Sharp ER A550S. However, all of the reports run fine, but it beeps as if locked up in regular mode. When trying to redo the alpha code, it beeps and errors when the @ key is pressed
    Sergeant:
  • 329 Answers
First check to be sure there is not a key stuck down. Not sure what type of cash register you have. Many times you have to perform a RAM clear and reprogram. Sounds like you have lost the program. Also is the drawer closed some registers have a switch and also need programming to operate the keyswitch with the drawer open...Good luck
Posted on Jun 28, 2008
My ER-A330 register wants to beep every time I try to ring anything up.
You forgot to sign on. It has no operator assigned. Enter your PIN number and press CASH# button in top corner of keyboard. If you have forgotten your PIN number for sign on, you can program new ones. One of the users has programming manuals here:
https://the-checkout-tech.com/manuals/cashregisters/Sharp7.php
May 24, 2016 | Sharp ER-A330 Electronic Cash Register
Reprogramed tax after initializing Sharp ER-A330 now will not accept any sntry
I believe the ER-A330 has a Cashier # button - it should be labeled CASH #. It has to have a cashier signed on to ring a sale. Most owners forget that, because the same cashier stays signed in all the time, and nobody uses the button. If I'm right, all you have to do is this (in REG mode):
[CL] 1 [CASH #]
and start ringing your sale. The CL was to clear the error condition, if it was in one. 1 CASH # assigned Cashier #1 to the register.
The reason the register has the button is so it can track sales totals for each employee or shift. The register can be programed to stick with one cashier until another is signed on, or it can force you to sign on for every sale. At the end of the day it can print the normal Z totals by touching the CA/AT key, and touching the CASH# key gives totals for each cashier, I think.
Initializing the register cleared the cashier assignment and got you into the predicament. Touching the CASH # key twice will also clear the cashier assignment, as will resetting the Cashier totals with a Z reading. In any of those cases, just go back to REG and touch 1 CASH# again (or a different number if you want to sign on a different cashier).
Oct 23, 2012 | Sharp ER-A330 Cash Register
Casio te error 01 On normal reg selection all buttons are non responding to anything. On all other mode switches an error code 01 appears. What do I do?
Try this:
Turn key to PROGRAM mode.Turn power off at wall.Hold RECEIPT FEED down - keep your finger on it.Turn power on at wall.Wait 5 seconds, then let go of RECEIPT FEED.You should see "FFFFFFFFFF" on display.Press SUBTOTAL.Now turn back to REG mode. You may need to sign a clerk back on
Oct 18, 2011 | Casio Parts Cash Register PC Desktop
Error modo e001 casio fe5000
You have probably turned the key before you finished. Turn the key back to where it last was (the error will stop). Then finished what you started in that mode before turning the key again.
Feb 03, 2011 | Casio Parts Cash Register PC Desktop
E32
In Sharp registers, Error 32 means no cashier is signed on. It should be just a matter of touching 'CL' to clear the error, then '1' "CASH #" to sign on as Cashier 1. Go straight from there to entering a sale.
Sharp allows a program option to force signing on before every sale, but it's not the default. Somebody probably accidentally signed off by touching the CASH # button without a number.
Another program option which probably doesn't apply here is to hide the cashier code, putting only dashes or stars on the display & receipts. In that case you have to enter CASH # [code] CASH # to sign on.
Oct 21, 2009 | Sharp XE-A402 Electronic Cash Register
TK-1550 cash register e037 digit or amount limitation over
It sounds like you have a lock out high amount limitation.
email me so I can send you a picture that will explain it more. My email is deborahrainwater@bellsouth.net
In the subject put the Eo37 error code so I know it it from you. The picture explains it, I will try to explain it since it will not let me paste a picture on here. On one of the programming keys it has been programmed (came that way, or accidentally done) that locks the register if a certain limitation of amont of money has been totaled. In your case $30.00. The manual should show or tell you how to unprogram or change the high amount limitation.
May 26, 2009 | Casio Parts Cash Register PC Desktop
Eror code E01 in sanyo ecr 140 cash register
Hi.
Sanyo information is very scarce as they are a very small player in the register market now, so I have no details on the 140. However, the standard error E01 usually refers to lack of clerk. This means you must sign a clerk onto the machine. See if you have a clerk or cashier button. Press 1 then clerk.
Jan 27, 2009 | Casio Parts Cash Register PC Desktop
Casio PCR-T2000A Cash Register
i have a casio cash register pcr-t2000a and i keep getting an error code e 026 enter condiment then preperation plu no matter what i do i cant seem to get it fixed it wont let me use the register with this code
Aug 29, 2008 | Casio Parts Cash Register PC Desktop
Need help please for my ce3700
Hi.
Error 8 means you have no clerk (operator) signed on to use the machine. You need to find your CLERK or CLK# button. Firstly, press 1 on the number pad, then CLK# or whatever the button is labelled on your machine. Some versions have 4 push down type buttons near the mode key, above the keyboard. If they are there, make sure one is pressed down also.
Good luck. Let me know if you have trouble.
Mark
Aug 09, 2008 | Casio Parts Cash Register PC Desktop
292 people viewed this question
jasbo
jasbo
