Can you give the specifications of your PC including which video card your using.Is it an inbuild or an expansion ..If an expansion then which one NVIDIA or RADEON?Can you give the specifications of your PC including which video card your using.Is it an inbuild or an expansion ..If an expansion then which one NVIDIA or RADEON?
You can't post conmments that contain an email address.
the computer might not recognize your video card and you might have to download a driver for it If your computer came with a motherboard disc the drivers
could be on it
Click start control panel administrive tools computer
management device manager scroll to display adapters + to expand you might see
a yellow question mark ? or exclamation mark ! or a red x right click select
reinstall drivers
Want to make sure your drivers are in place and no errors
have occurred? Simply click start right click on my computer select properties
then select device managerscroll to
Display Adapters and click on the small "+" you should see the model of
your PCI Express graphic card there. If there is a problem with it, a yellow
exclamation mark should appear besides it. If you don
To fix the error, you need to download and install the latest DirectX version on your system. If you are not sure of which DirectX version is running on your system, perform the following tasks to find out:
Open Start menu and select the Run command.
In the Open box, type dxdiag and press Enter to open the DirectX Diagnostic Tool window.
Here, you can find the DirectX version that is installed on your PC in the bottom part.
You might have to download and install a later/better copy of Direct X Hope this helps
