Question about Biostar M7VIT 800 (M7VIT8A02) Motherboard
Instantly shutdown hy i have a computer with a BIOSTAR M7VIT-800 MOBO, SEMPRON 2,6+, 2x256DDR1 and FX5200. The problem is that if i try to boot from hdd or cdrom the computer will shutdown in about 30 minutes, if i stay in bios or just on boot screen nothing bad or abnormaly happens. I already verified the memory,hdd,processor,video board and i have allready changed all the wires in the computer, reseted the bios Please if anyone has any other sugestion i will be grateful By the way this configuration worked normally for about 2 years. Thank you all
  • sorinb Jun 30, 2008
    i have already cleaned the fan and heatsink and changed the thermal grease, and the problem is not only on windows, even if i tri to bootup from a dsl live linux (very light weight linux) or just to reinstall windows it still crashes
    i have allready cleaned the fan, the heatsink and u have changed the thermal grease, the computer crashesh even when the processor temperature is at 42 Celsius grade, i tried to bootup from a DSL live cd (which is a very light weight linux distro) and still crashes in the moment when trys to read the cd, i tried to reinstall win and the same thing
    President:
  • 1,314 Answers
This sounds like it could be a heat issue. When you're in windows, you're using the processor more than if it just sits idle in BIOS. Using your cpu creates more heat. Make sure there is no dust in the fan or the heatsink on the cpu. Also, remove the heatsink and clean the old thermal grease compound off the heatsink and cpu and reapply fresh thermal grease.
Posted on Jun 27, 2008
I have a biostar board A740G M2L, I want to know if the sempron processor will work?
Hello
A740G M2L+
Click here this is the specification sheet for your Mainboard.
Yes, Sempron AM2/AM3 processor will work.
Best of luck building your PC it is very exciting.
Oct 24, 2010 | AMD Computers & Internet
Hi-low beeps at boot. System won't even get to BIOS.
That is probably your ram. If you have more then 1 stick remove them and install one at a time in slot 1. If that isn't it you need to count the beep and duration of the beeps. I can then look up the codes. I will also need to know your bios manufacture.
Jul 09, 2009 | Biostar M7VIT Motherboard
After installation no video output
Hi there.
Take out the ram (memory) clean the slots and the brass pins, reseat the memory and try to boot, also can you tell me if you use on-board or a separate graphics card?
May 25, 2009 | Biostar P4M80-M7 Motherboard
System not booting, after installation
Update the driver by using xp , not the installer.
 Start . Right click,MY computer,click properties,click hardware,click device manager, click display adapters, click Update driver.
Mar 05, 2009 | XFX GeForce FX 5200, Graphic Card
Windows not loading
Appreciate the direct "Ask Me".
Whenever Microsoft Windows XP is installed on a system, the OS is binded to the motherboard, specifically to the chipsets. I am assuming that when you replaced the motherboard, the OS was not reinstalled and it was still binded to the original Dell Dimension board, most likely an Intel 925X Express chipset. When the OS started to load, it could not find the original 925X chipset and instead finds itself confronted with Biostar VIA P4M900/VT8237A chipsets which is an unknown, hence the BSOD.
You could try:
  • boot from CD drive with an XP installer and use the second repair option;
  • boot into Safe Mode (F8) and try to uninstall the Intel devices entries (except the CPU) and allow the system to auto detect (if it will) the new hardware;
  • backup your files and perform a fresh/clean install on the new motherboard.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 05, 2008 | Computers & Internet
Geforce fx5500
timber710,
Please remove the geforce fx5500 video card. Blow out the AGP slot with some canned air. Re-seat the video card & make sure you install it with even pressure (front to back) with slight rocking motion untill the card is completly seated. Try running the system again. ( I'm thinking the card was not completly seated).
If your system freezes again re-set your cmos / bios. In your user manual pg. 2.
Boot to the bios & re-setup all your settings. Save & exit.
If your PC still freezes, try another AGP card because the 5500 seem to be defective.
So hate giving out bad news........
Luck timber710
Mar 09, 2008 | Biostar M7VIT 800 (M7VIT8A02) Motherboard
Cmos resetting
Ok so you know the bat is good cause you checked the voltage. You double checked the bios jumper making sure it is not set to clear. Looking in your manual you can go to AMD XP3200+, & you are under that. So either you have a short or your bios needs flashed because it's messed up. Could have went when the cpu died.
Jan 15, 2008 | Biostar M7NCD ULTRA Motherboard
P4M80-M4 not powering up
You may have the power and reset connectors on the right terminals, but they may need turning around, normal rule of thumb is if the markings on the connectors are on the outside, then turn them to face inwards.
Mar 28, 2007 | Biostar P4M80-M4 Motherboard
Biostar M7VIT 800 (M7VIT8A02) Motherboard Logo
78 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
