Question about Microwave Ovens
Model "KOT-152UW" The
Model "KOT-152UW" Daewoo microwave "e-wave". The night light was turned on overnight, in the morning the house circuit breaker had tripped and I reset it. Now neither of the lights, nor turntable motor, or the fan works, although the magnatron runs and items heat. Is there an internal fuse or circuit breaker which can be reset? The blade wire connectors on the lights are blackened (from overheating?) and the base of the bulbs look scorched. Where to from here?
  • Anonymous Apr 01, 2014
    DOESN`T COME ON
    NEED TO KNOW WHERE TO BUY IT
  • Microwave Ovens Master
  • 6,487 Answers
A fluorescent display tube power supply device of a microwave oven provides a stable power source for the microcomputer by rectifying the output of the first secondary coil of the commercial AC power transformer, followed by rectifying a half wave of the second secondary coil of the same AC power transformer before feeding one-half cycle of the commercial AC current to the heater of the fluorescent display tube. The power supply uses a rectifying circuit for generating the double voltage for the second secondary coil, the double voltage being mixed in the direction in which it becomes lower than the stable voltage of the microcomputer, thus generating the display erase potential VP. As a result, luminance can be held constant respective display positions without causing the voltage of the display tube to vary throughout the ON-OFF operations of the heating power source, thus eventually achieving a highly satisfactory display effect. Hope that helps.....
Posted on Jun 27, 2008
  • Mark Gil
    Mark Gil Jun 27, 2008
    There is a fuse in the microwave that can only be accessed by taking the cover off the microwave.
    This is the fuse the control the power to the board.
    check this link if your model is listed for the stpes. microwave model tmv151fs.
    Brigadier General:
  • 3,614 Answers
Well inside the unit check for any burn fuses on the power supply area, and into the control board. fuse basically the one will tripped if power surged occurred..
  • micromaster
    micromaster Jun 27, 2008
    and also check the diode that was connected to the capacitor, this is near the transformer.
What is the Serial Number for the EWAVE KOT- 17sb? It does not display it in the information panel.
Hello, Marisel -
Do you mean the Daewoo KOT-170SB microwave oven, instead?
The manual for the KOT-170SB microwave I found online (PDF format):
pdfstream.manualsonline.com/1/1d0dd7b3-990b-4256-9519-fa2dc1e7c2bf.pdf
shows a "data plate" on an interior wall of the microwave (page 7.)
That may be where the serial number (S/N) for the microwave is printed.
If not, there may be a label or tag at the back of the microwave oven where the serial number (S/N) is printed. Or, there may a label on the back of the microwave oven, look on the bottom.
Best wishes.
Feb 08, 2018 | In Microwave Ovens
Hi. I want to replace my Daewoo KOT 210UW over-the-range microwave. I need to know the size of the hood opening. How do I find this information?
All over the range microwaves are 30 inches. All the ducting is the same also. So you can replase with anyone you would like.
Dec 28, 2009 | Daewoo Microwave Ovens
Touch Control panel of my daewoo KOT-151S microwave needs to be replaced. I have to push control pad several times to get it to operate. Sometimes it will go on after just a few pushes, other times it...
We regularly replace these.
You can send your KOT-151S control panel assembly to us to install a new membrane keypad. The cost would be $64.95.
Or you can order an entire control panel assembly (plastic frame, stainless trim piece, keypad, and control circuit board) for $88.85, which includes return shipping.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 31, 2009 | Daewoo Microwave Ovens
Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Jul 13, 2009 | Daewoo Microwave Ovens
Daewoo over the range microwave model KOT-21OUB just stopped working for no apparent reason. Lights and fans still work. Not heating food. Worked for one dish then the next nothing.
how old is the machine, microwave ovens have a tendancy to do the ridiculous for no possible reason. a check of the main power fuse within the unit might help. it is a large fuse 10A> that supplies the transformers
Feb 17, 2009 | Daewoo KOR-630A Microwave Oven
E-wave microwave model #kot-131uw just quit all of a sudden
Is it dead, meaning no display, no light when you open the door and no beeps when you press a pad on the keypad
Dec 03, 2008 | Microwave Ovens
Replace OTR Microwave
Thanks for responding. It is a EWave KOT-152UW. I think EWave is part of Magic Chef. I think it is the door switch. When I opened the microwave, the circuit breaker tripped. I reset the circuit breaker, and it worked for several days, but the last time, the microwave went dead. The reason I want to use the same bracket is it has through the wall (horizontal) venting to the outside, and I am not keen on trying to cut more holes.
Nov 04, 2008 | Microwave Ovens
Microwave Ovens Logo
141 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
