Question about Compaq Presario Notebook
Compaq Presario 1255
My sister gave me an older laptop, Compaq Presario 1255. When I power up the laptop, I receive a blue box with the following in it with a space following it to enter a password, "Enter Password". She had never seen this before and has no idea what password to use. When I try her password, I get system locked message. Can you help?
  • Blankzer0
    Blankzer0 Mar 12, 2012
    If the prompt for password is before the windows logo come on then you may have a BIOS password that you may need to enter before the computer boots. This was common with older computer for security reason. If this is the case then you can bypass this if you do not know the password by removing all power to the system and then remove the motherboard battery.
    Guru:
  • 1,342 Answers
Check this site for some tips and tricks that may help you.
Posted on Jun 27, 2008
    Genius:
  • 2,028 Answers
If there is a cancel button with the password prompt, hit cancel without entering a password, or hit enter without entering a password. Sometimes if there was a password, even though there may not be a password currently, the system will still prompt for one, if you enter a password then it locks. The other things you can try is: At start up, hit the F8 key and go into safe mode, log on under the administrator and clear any user passwords in the user accounts. You can also try, at start up, entering the bios or utility set up and check to see if the bios password setting is enabled, then disable it. Rarely, but on occasion, a hard drive will fail and cause the password prompt. If this is the case, then the hard drive will need to be replaced.
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
COMPAQ presario cq57 has a blue screen and white curser
This means nothing specific, try to load Last known good configuration, by holding F8 key right after power on, until it shows Windows boot options. You should also check memory, hard disk drivers and viruses, but this is much longer explanation, so ask if needed.
Dec 01, 2012 | Compaq Presario Notebook
Compaq Presario v2000 freezes
If your laptop freezes randomly follow the steps given below:
  • Disable Unnecessary Services
  • Run Disk Checkup
  • Disable Startup Programs
  • Clean Registry Errors
You can also get more help from this article:
http://www.backspacetab.com/laptop-freezes-randomly-tips-to-fix-this-problem-for-good/
Dec 08, 2011 | HP Compaq Presario V2000 Notebook
Before to start laptop appair the following error: 0270 real time clock error. save to disk file not found save to disk feature is disabled run phdisk for information.FILE:create new. ...
compaq is HP so best is to ask them, there, now here.
RTC error mean , the RTC coin cell is dead.
all PCs this old are dead battery ,
RTC= real time clock chip says IM DEAD, but is battery dead ,..
remove the coin cell, and put in a new one.
end story.
then set time .
best is to set time in BIOS setup. 1st.
this Compaq is 18 years old now. or 126 dog years.
id , push it off a cliff on the 4th July with fireworks. and all.
let me guess its XP the VIRUS magnet.
some this old are windows 98
a hopeless case there, no? no support, no books and no updates.
the books at HP are long gone
so now all books are , sold by horders. $$$
it can be costly and dangerous to deal with folks like that.
the book you lost , , the answer is on page 18
seen here
see coin, remove it and put in new one. end story.
https://www.manualslib.com/manual/30167/Compaq-Presario-Presario-1255.html?page=21#manual
Jun 27, 2017 | Compaq Presario 1255 Notebook
My compaq presario c700 power ons but gives no display i gave it to a service centre they told that the mother board processor circuit is in short how to clear the short
If the notebook appears to boot up and the hard disk LED flashes the the fault could be a backlight problem. Please click on this link and follow my instructions to determine the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 21, 2010 | Compaq Presario 700 470024-192 Notebook
My Compaq Presario F756nr will not turn on. The b...
Having the same issue. Did you find a solution yet?
May 20, 2010 | HP Compaq Presario F756NR Notebook
Recently repaired compaq presario laptop has startup issues
******** and your laptop this link is full of **** do u want if yes bring your sister and when i **** her then i will till you what to do ******** man
john
Jun 21, 2009 | Compaq Presario M2000 Notebook
Compaq evo n400c
copy the files off the cd, then execute them...
Sep 09, 2008 | Compaq Presario 700 470024-192 Notebook
Presario 2100US not powering up
remove power supplay
remove battery
press and hold power button for 1 min
release button
plug the power supplay
turn on laptop without battery
Feb 21, 2008 | Compaq Presario 2100U Notebook
Compaq Presario Notebook Logo
137 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
