Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Model 5710 I have had this unit for several years but have not used it. When I use the PTT it does not transmit or receive. Everything else works fine.
  • mcasagra Mar 09, 2009
    Mine has the same behaviour. I have already set frequencies scanning and so on,but they can't communicate
  • Motorola Master
  • 1,654 Answers
You need to check your programming of both frequency and interference eliminator. You may not have your radios set to match one another.
Posted on Aug 06, 2008
I have two T6500 walkie talkies that have worked well for several years, suddenly neither can transmit. When PTT is held, nothing happens on either handset. we get random transmissions/static so it seems...
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units.
Dec 28, 2013 | Motorola Talkabout T6500 (7 Channels)...
Kenwood tk 3102 and autocom
moz-screenshot-1.jpgmoz-screenshot-2.jpgPlease use the link to get the manual:
http://inform3.kenwoodusa.com/Manuals/USA_LMR%5CTK-2100-3100_B62-0950-30.pdf
good luck......................
May 17, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
My walkie talkies arent communicating when i press the ppt button. it transmits too fast before i get a chance to talk into it. what can i do to fix them? is there a reset button? they are the motorola...
The ACTUAL problem is your rechargeable batteries have most likely depleted over time, and since it takes more batterie power to transmit than to receive it can appear that your batteries are fully charged and you can be receiving but due to the batterie it will be unable to transmit
Jul 26, 2011 | Radio Communications
Makes loud tone when pushing ptt button
The ptt switch or circuit is not disconnecting the audio circuit. Open the unit up and check the wiring, interconnect plugs for something shorted not canceling the receiver audio.
May 10, 2010 | Radio Communications
Radio stuck in RX mode.
Your PTT button is possibly at fault. It may be partially depressed, leaving your receiver open. Behind your PTT button there is an internal PTT button on the componet board. It may be stuck or defective.
Feb 28, 2010 | Radio Communications
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Aug 27, 2009 | BellSouth Radio Communications
T8500 blinks off and back on often when transmitting
It takes more energy to transmit than to receive. It is possible you have an old or defective battery pack, a bad connection to the battery, or your PTT button is not working properly. On this unit, the internal PTT button can begin to be bent further in from repeated use, or pressing too firmly.
As far as a more durable/reliable radio, you might want to look at radios in the business division such as the Motorola CP110, BPR40 or the CP150. These business level radios are built to work a 40+ hour work week, and are much more reliable than the consumer division products, which are intended for occasional usage.
Jan 17, 2009 | Motorola Talkabout T5720 (7 Channels)...
T5420 unable to transmit or receive. Please help!
Here is a link to the T5000-T5500 user manual. 'http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf'
From what you have stated, I can discern the radios will power up. You might try setting your interference eliminators to zero (off) to see if you are able to transmit at all.
You do not mention if you are using AA batteries or rechargeables. Either way a fresh set of charged batteries would be best for a test. It is clear you were getting power. However, it does take more energy to transmit than to receive. If your batteries are low or bad, pressing the PTT could us all the energy the radio has, and yet not transmit to the other units.
You might also check you VOX settings if any and be certain they are turned off.
It is not likely 4 radios would fail all at the same time. So it is probably a programming problem. Hope the user manual helps you find the solution.
Aug 23, 2008 | Motorola Talkabout T5420 (14 Channels)...
One radio continually transmits
Hello
This could be the Ptt Switch , Midland is 3 Years warranty try to claim the warranty, this is a Factory fault.
Oct 25, 2007 | Midland LXT303-A 2-Way Radio
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
149 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
