Question about Panasonic PT-53WX42 53" Rear Projection Television
Problem with HD feed from satellite receiver
When I set my satellite receiver (Bell ExpressVu, Dishnet) HD output signal to 1080i, then i get ghosting: blue, yellow, red. This looks like a convergence problem, but I checked the convergence, and it seems to be fine. This ghosting does not happen when I set the HD output to 480p, but then I don't get a true HD picture. The TV was manufactured in 2002. Any ideas?
    Problem Solver:
  • 3 Answers
I just had my HD DTV installed this weekend, you have to leave it on 480p. I too purchased my tv in 2002. Per DTV, its an older model and you have to stay with the 480p to get the best possible picture. I have to admit, don't know what the 1080i looks like, but 480p is showing me a very good picture. Best I have ever seen on my TV.
Posted on Jul 21, 2008
Haier tv I am hooked into Bell Expressvu. HD receiver and I can't get the picture to expand to the entire tv screen. i can only find HD Normal and it stays in a small screen view.
It might be necessary to change the resolution/Aspect Ratio (Screen Size) settings on both your HD Receiver and your TV.
I don't have Bell Satellite but I do remember having the same issue setting up my friends HD TV and Bell Satellite TV Receiver.
Nov 25, 2013 | Haier HL32D2 32 in LCD TV
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
TV set always starts up indicating 420p. How do I get it to 1080?I have Bell expressvu HD
is your cable or sat in HD(720p, 1080i, 1080p) over the air broadcast in the usa is in digital so it should start at the highest res available in your area
next are you using HDMI or composite for your cable or sat going into your tv if not your not going to get higher than 420p because A/V and S-video do NOT support HD
check your cable/sat box is it HD(high def) or SD(standard def) if SD going through cattv/attn in your only going to get 420p
now for changing the resolution its automatic it goes to the highest setting on its own
you can control the resolution through your cable/sat box, blue ray/hddvd player and other HD devices connected to the tv through the options menus of those devices BUT only when connected through
HDMI(supports 720p, 1080i, 1080p)
composite(supports 420p, 420i, 720p)
A/v and S-video(supports 420p)
cat tv/attn in(supports 420p, 720p, 1080i, 1080p) only supports what the tuner will do
Feb 11, 2010 | Hisense LHD3204US 32 in. LCD HDTV
Sharp Aquos lcd tv
Check Dishnet setting System of your Dishnet It should be NTSC/PAL/SECAM select as per your country
Jan 21, 2010 | Televison & Video
The receiver is connected via an Optical audio cable to my Bell ExpressVu HD receiver, When watching HD programming the Dolby Digital breaks up, I then have to switch to "virtual" setting to get sound. I...
my rule is to always install an analog connection to any device along with a digital connection as a "backup", if you will. set the input on the receiver to auto and the rest is like magic with functional equipment. sometimes digital signals do flutter and become intermittent. the receiver will then switch to analog to keep the game goin.
Nov 03, 2009 | Denon AVR-1602 Receiver
I have a Sharp Aquos LC-30HV4U which is supposedly HD ready. I am a Dish Network satellite subscriber. I do not know what to do to make this HD ready set receive HD signals.
Your reciver is already set for the hd. Alls satellite programing and cable already come in hd format. You can also get any info here.
Good luck and please rate FixYa!
Apr 07, 2009 | Televison & Video
Combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Sep 18, 2008 | DISH Network Televison & Video
Replacement remote for bell expressvu
Here is the link to pdf document:
Feb 14, 2008 | DISH Network IR Remote Control
Bell Expressvu 2700 satellite receiver av inputs
had my 2700 reciver unpluged for awhile now can't my channels back can you give me any idea how to fix this
Jan 01, 2008 | Televison & Video
Hitachi 53SDX89BA HD settings
Problem more than likely with the xbox, as the output stream of data from the game platform is not always consistent...accordianman
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
1,147 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
