Question about HP Officejet 5610 All-In-One InkJet Printer
To adjust the size of the copied images
Please let me know how to adjust the image of the copies to be 100% of the original.
I am just trying to make normal copies of some documents. But they come out smaller than normal.
Thanks
Roger
My email is rogerchuy@gmail.com
1. Press the COPY botton repeatedly until the Reduce/Enlarge menu shows up.
2. Press the > until you reach the setting you want.
3. Press the COPY key repeatedly again until SET NEW DEFAULTS appears.
4. Press > until YES appears and then press OK.
I found this from the Owners Manual that I downloaded, but have not tied it yet.
I think it should work. It is for a friend of mine.
Posted on Jun 28, 2008
How to copy legal to letter on copystar CS 4005i
Make sure your default settings are for AUTO paper selection and 100% magnification to start. That is the most common default settings. Then, under "Zoom" change to AUTO magnification and under PAPER SELECTION specify Letter (either landscape or portrait). Now when you copy a legal original (8.5" x 14") it will be reduced at 78% to fit it on an 11" sheet. An alternative is to use "X-Y" zoom. Now you can stipulate 78% for the "X" dimension and leave the "Y" dimension at 100%. You will want letter size paper to be feeding lengthwise (portrait). Now you can copy legals and the image is reduced top-to-bottom only, leaving it much more readable.
Mar 16, 2015 | Copystar Office Equipment & Supplies
Image Faulty
there are paper guides on either side of the paper in the bypass.make sure thy are nice and snug right next to the paper.
Mar 07, 2014 | Kyocera Mita KM-1650 All-In-One Printer
Canon Color imageRUNNER C2550 legal size copying only works with single pages placed on the glass. Auto feeder ends up with image off center
when you making the copies, you MUST adjust the paper guides on adf/dadf. They are gray plastics left and right from original and can be moved to each other. They guide the paper rightly in adf/dadf.
If these doesn't helps, please describe what happens when dadf pulls the paper inside.
Apr 21, 2011 | Canon imageRUNNER C2550 Color Copier
Cut the copy of image
SET THE ORIGINAL SIZE AND THE PAPER TRAY.Change the security values.
Aug 20, 2009 | Minolta Office Equipment & Supplies
Print or copy at A3
you will ahve to set this in the print properties when you select print on the file option go to paper and select bypass if you are using this tray and original size will be A4 print size will have to be set to A3
May 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
Need to know how to use the scanner on a lexmark 6500
You can change the resolution (dpi) of an image or of the copies you're making from the 6570. Here's instructions on how to do both:
Change the resolution of copies:
1. From the operator panel of the printer, press Copy Mode.
2. Press the menu button.
3. Press the arrow buttons until the Quality option appears.
4. Press the check to select Quality.
5. Press the arrows until the quality you want appears (you can't choose a specific dpi here, but you can adjust the quality).
6. Press the check to select it.
7. Press Start Color or Start Black.
Change the Resolution of an image:
1. Open Productivity Studio.
2. Click File > Open and select the image you want to edit.
3. Click Advanced.
4. Click Image Resolution/Size.
5. Select Photo Size to select from a list of defined photo sizes, or click Custom Size to enter a different size.
6. If you select Custom Size, type the width and height you want to use for the custom size.
Jan 19, 2009 | Lexmark X6570 InkJet Printer
Text moves down the page when I copy - how can I stop this?
Sounds like it is either resizing the image or not seeing all of the original.
Specify the original size and do not use auto.
Make sure thsat image shift or image centring is not on.
Jun 16, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Scanner not responsive. You can choose to have the document scanned to your PC but nothing happens and either location.
Hi, we need to check first if this issue is caused by the scanner it self or by the scanner driver. Please try the following to check if your scanner is physically functioning or not:
Basic Copying
1. Open the scanner lid.
2. Place your document face-down on the glass. Move your document about 0.1 inch from the top and side edge so your entire document is scanned.
3. Close the scanner lid.
4. Be sure the COPY button is lit. The default copy settings are displayed on the control panel.
5. Press the Color Copy button (for color copies) or B&W Copy button (for black and white copies). Your document is scanned and then printed.
Note: Depending on the copy settings chosen, your copied image size may not be the exact same size as your original.
If the image was successfully copied please uninstall the scanner driverm download the latest driver in http://support.epson.com and install it. Try scanning.
If the issue still present we will need to ensure the scanner is being recognized correctly. Have you had any other scanners installed on the computer previously? We would suggest checking the DEVICE MANAGER for any conflicts.
Get to the Device Manager by:
1. Right-Clicking on MY COMPUTER
2. Left-click on PROPERTIES.
3. Click on the HARDWARE tab, then DEVICE MANAGER.
In the Device Manager please for the following:
1. Any yellow or red X's, question marks or exclamation marks.
2. Under the Category of Imaging Devices - Check for Epson Product name.
If IMAGING DEVICES is listed, test the scanner from PAINT.
To scan in paint:
1. Click on START > ALL PROGRAMS > ACCESSORIES > PAINT.
2. Click on FROM SCANNER OR CAMERA.
3. Choose COLOR PHOTO.
4. Scan.
It is also possible your Windows Image Acquisition (WIA) service is not started.
To start this process please follow the steps listed bellow.
1. Click on Start, go to Control Panel.
2. In the Control Panel window you will Performance and Maintenance, please left click that option.
3. Next we are looking for Administrative Tools, please left click on that option.
4. We are looking for the Services icon please left on that icon.
5. In the Services window we are going to scroll down to the bottom and look for the Windows Image Acquisition (WIA) Service, Please Right click it with your right mouse button.
6. We want to select the STOP option with your left mouse button.
7. Next we want to Right click on the Windows Image Acquisition (WIA) service again and select the START option with your Left mouse button please.
Tirzo
Jun 16, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Dark line when trying to make original copies.
The type of printer you have reads the image you want to copy by passing the paper in front of a image reader (it is like a wand with a light-slit on a side).
If someone passed in front of this reader a paper with something like dirt on it (or typing corrector not dry enough) some of that could stick ON the light-slit, so that the section covered with it cannot read any more the image you want to copy at that point!
Try to make a copy and look from above or aside where that light-wand is located, then try to clean it with a clean hanky. It could involve some technikal skills, maybe you have to loose some screws to get to it.
If dirt stick on it after this, try with some alcohol (no solvent please!). After cleaning the reader, copies should come out ok, please let me know.
Rate the solution please! Thx
Jan 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Print Qualityfor DC12
I am not 100 percent what you are asking but I will answer the best I can with your question.
  1. Press the [Administration] button located above the numeric keypad on the Control Panel. The Administration button has a wrench symbol located above it. The Access screen will be displayed.
  2. Select [Tools] on the Touch Screen. The Tools Access Number screen will be displayed.
  3. Enter your numeric password using the keypad.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111.
    If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed:
  4. Select [Enter] on the Touch Screen. The Tools screen will be displayed.
  5. Select [System Image Quality]. The System Image Quality screen will be displayed.
  6. Select [Image Recognition]. The Image Recognition screen will be displayed.
  7. Select 'Screening Adjustment' by selecting the [Up] or [Down] arrow buttons.
  8. Select [Change Settings]. The Screening Adjustment screen will be displayed.
  9. Select [Apply to Copies Only] then select [Save]. The Screening Adjustment screen will be displayed.
  10. Select [Close]. The System Image Quality screen will be displayed.
  11. Select [Auto Screening Adjust]. The Auto Screening Adjust screen will be displayed.
  12. Select [Halftone Screen]. The Halftone Screen will be displayed.
  13. Select either [Halftone 200 line screen] or [Photograph 200 dpi].
    NOTE: Do not select 'Printer use' as this will effect print calibration; which will be handled directly by the color server set up to print to the copier / printer.
  14. Select [Save]. The Auto Screening Adjust screen will be displayed.
  15. Insert at least 2 sheets of white, 216 mm x 279 mm (Letter, 8.5 x 11 inch) paper in Paper Tray 5 (Bypass Tray).
  16. Select [Print Test Original] to print a sample of the settings. The message 'Please wait…Printing test original' will be displayed and the test original will print.
    NOTE: If selecting [Print Test Original] displays the message ‘System Disabled' then Screening Adjustment is disabled. Select [Close] and repeat steps 5 to 16.
  17. Open the Document Glass Cover.
  18. Place the test original face-down on the Document Glass with the two magenta squares against the left edge of the glass.
  19. Place 5 sheets of blank white paper directly on top of the test original.
  20. Close the Document Glass Cover.
  21. Select [Start Adjustment] from the Touch Screen. The message 'Please wait….Adjustment in progress' will be displayed, then the Auto Screening Adjust screen will be displayed.
  22. Select [Adjustment Complete]. The message 'Please wait…Printing current settings' will be displayed and the adjusted original will be printed.
  23. Examine the adjusted original to make sure the image quality is satisfactory and continue to the next step. If the image quality is not satisfactory repeat steps 12 through 22.
  24. Select [Close]. The System Image Quality screen will be displayed.
  25. Select [Close]. The Tools screen will be displayed.
  26. Select [Close]. The default copy screen will be displayed
Dec 27, 2007 | Xerox DocuColor 12 Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
76 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
