Question about Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
Computer beeps three times and will not start
I installed ddr memory 1gb 3200,and then the beeps began,i removed the ddr memory and put my old ddr memory back and it stll beeps, and the computer wont start.
  • 3 more comments
  • adamakajohn Jun 27, 2008
    it beeps three times
    thanks for the advice,Question. do i put my old ram back in or do i use the new ram?
    thanks for your advice, do i leave the new ddr memory in or put my old ddr memory in instead?
    i turn it on, the fan powers up, the two lights on the front turn on, when only one turns on normally, then it powers down. then it powers up again the keyboard lights up the monitor light turns on but nothing on screen then it beebs 3 times, 1 short beep then two long one,s,then it will not turn off . so i have to unplug it from the back. Then when i plug the power back in it then it does the above again.
  • ianwriterema Dec 27, 2008
    My vista HP laptop beeps three times on startup -- then nothing. What does this mean and what do I do about it? Switch to a Mac, maybe?...Im getting really tired of PC problems!
Continuous beeps on the motherboard fox 915m12 gl gls
what would be the cause of this problem
Fabricio Brazil fabricio.col@bol.com.br
Posted on Aug 27, 2008
    Guru:
  • 1,342 Answers
Strange that the old memory no longer works. Make sure that you are seating it properly and securely.
You can try discharging the motherboard by unplugging the power cord and holding in the power button for up to 60 seconds.
Posted on Jun 27, 2008
  • 144 Answers
Clear CMOS/ Remove battery for 10 minutes, reinstall battery & wait for another 10 minutes before turn on. Three Beeps means RAM is defective/ not detected.
  • Anand Salunke
    Anand Salunke Jul 01, 2008
    Try with new RAM. Check your motherboard's documentation for compatible RAM. May be the slot accumulated a lot of dust. Try with different slot also.
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
Memory ram
According to SiS® official document, SiS® 748 chipset has limitation DDR supports:
CPU at FSB 200MHz mode, it will NOT support DDR400
CPU at FSB 333MHz mode, it will NOT support DDR200
CPU at FSB 400MHz mode, it will NOT support DDR200/DDR266
Depends on chipset http://www.asrock.com/mb/overview.asp?Model=K7S8XE
Jul 22, 2009 | Computers & Internet
Installed new memory. will not restart, rear
That could be a couple of different issues.
  • Memory may not be seated all the way. It should "snap" into place.
  • Make sure it's right kind of memory. The Dell Dimension 3000 takes 333MHz DDR SDRAM. Look on the chips to see if it says 333 or PC3200 anywhere.
  • The max memory for that machine is 1GB, so my guess is each memory card is probably 512MB max. Larger ones may not work
  • It's possible the memory is bad, replace it as last resort if nothing else fixes it.
Let me know if none of the above works.
Apr 07, 2009 | Dell Dimension 3000 PC Desktop
What is the ram limit of HP Pavilion 061 DW234A-ABA A530N I have two sticks of kingston 512 in it right now but want to put in two sticks of 1 GB each. Can I? Nvidia 7800 GS OC with 500 watt power supply,...
From the HP specifications page for Pavillion A530N:
Memory type DDR Memory speed PC 3200/2700/2100/1600 Memory sockets Two DDR DIMMs (184-pin) Maximum HP/Compaq approved memory Two x 512 MB DDR-DIMMS, 1024 MB total (1 GB)
Mar 10, 2009 | ASUS Computers & Internet
Added ram, now wont boot long beep
try removing the ram and try again
Jan 04, 2009 | AOpen AX4B-533 Motherboard
Black screen and three beeps
your m/boar is now not supporting the ddr which you are putting in, so you have to replace your ddr with Kingston DDR it'll solve the problem
Dec 06, 2008 | ASUS K8V-MX Motherboard
Cant Start Up
Hi
start with removing the added ram try starting up, if it doesn\t start up does it beep?
if noting happens remove all the ram, the computer should definitely beep now.
Add only the original memory and try starting up you should get picture.
This seems to be a old problem and if you don\t need assistance in solving it. It would be great if you would share to the world how you fixed your problem so other users can benefit from your experience.
Thank you, Ekse
Sep 28, 2008 | Corsair Memory Value Select 1GB PC2700 DDR...
SAMSUNG 1GB RAM 400MHZ PC3200
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
Or
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard Logo
1,896 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
