Question about Sony Dvcam DSR-PD150 DV Digital Camcorder
Sony pd 150 pal format.
When I turn my camera on, the color LCD shows a blue cast and it is very sensitive to bright light. I know how to Color balance and I've tried everything I could to rectify the situation.    Could it be the CCD chips?   What do you think?             Beau.
    Problem Solver:
  • 4 Answers
The 3ccd block asse. is damaged in your camera
changing it new one is only the way.
Posted on Jul 15, 2008
If it's a green cast, try adjusting the output (if such a command exists). Or, if there is a toggle for PAL or NTSC. You may need to change that.
Nov 25, 2013 | Fuji FinePix T400 16.0-Megapixel Digital...
What is the purpose of an R2 filter?
Each filter intensifies its color and darkens others, especially the color opposite on the color wheel. They're not of much use in color photography, unless you want weird color casts, but they come into their own in black&white photography.
For example, a red filter intensifies red and darkens blue. It can make a sky look almost black, making clouds pop out. Similarly it can darken foliage. A green filter on the other hand will brighten foliage.
If your camera can take black&white photos, try taking pictures of a red rose with green leaves with and without the filters. With one combination the rose and the leaves will be the same shade. With a red filter the rose will be bright against the dark leaves. With a green filter you'll get a dark rose with bright leaves.
With digital photography you can achieve the same effect in postprocessing, but some times its easier to get the result in camera.
Apr 28, 2012 | Quantaray 55mm Red R2 Lens Filter
My picture works but everything is a blue color, but it works
Have you set the format to PAL, NTSC or whatever the standard the camera is.
Feb 09, 2010 | Sanyo DS27510 27" TV
When connected DCR-SR42 to TV, video and images showing in B&W
yes ur TV might be set to color system PAL /NTSC and ur cam corder in opposite format there is color system changing button on every tv remote just try changing it to PAL or NTSC see if colors work and let me know and pls rate me if i fixed ur problem
Feb 25, 2009 | Sony Handycam DCR-SR40 Camcorder
Displays green color image/screen
When did you get this message? It seems like you have set the White Balance of the camera wrong. Set it to Auto White Balance to eliminate this problem. Use Daylight White Balance when shooting in bright daylight so as to eliminate any color cast in the image.
Feb 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Color or CCD not working
Is it playing correctly when you view it on a nobmal tv set?
If it is your lcd needs to be adjusted or replaced.
If it isn't recording it could be your CCD unit.
Either way you should take it into a camera dealer and have them look at it.
Jun 30, 2008 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Hi,My Sony digital8 dcr-trv140e is playing back in black & white this has only just happened other wise the camcorder is fine
If you are playing NTSC signal format cassette in your camera (model number shows it is PAL camera) picture result might be in B/W. go to camera player menu and select NTSC playback on PAL tv. Color will be there.
Jun 07, 2008 | Cameras
Canon 20D strong blue cast to pictures
You probably have the White Balance set to a setting other a
than "Auto White Balance" (AWB). On the top of the camera, above the exterior LCD panel, there is the "AF-WB" button. Turn the camera on--past "on" to the bent line. Press the AF-WB button once. On the left side of the exterior LCD panel there is a vertical, reticular box with the symbol of the selected setting for WB. Normally, the setting should be set to AWB. If it is not, turn the command dial at the back of the camera until "AWB" is showing. Try shooting again-the color should be better.
In the "auto" modes (green box, portrait, landscape, etc) the AWB is automatically set. In the "advanced" modes (P,Tv, etc) the WB is manually set for whatever light source you are using. The command dial may have been accidently turned to different setting. Hope this helps.
Jan 23, 2008 | Canon EOS-20D Body only Digital Camera
Mintek DTV-263 26in with No Color
please locate with your remote and change from NTSC to PAL or from PAL to NTSC while whatching cable
Jan 09, 2008 | Mintek DTV-263 26 in. LCD Television
Bright pink/red color
This is a defective CCD problem known to Sony. They'll repair it FREE of charge and even pay the shipping. Go here for details:
Dec 03, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Dvcam DSR-PD150 DV Digital Camcorder Logo
121 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
