Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Trips breaker when door opens
Started yesterday (although I didn't notice till water pooled up in front this morning. I can reset the breaker after the door is opened and it runs. Simply trips when I open the door. Light buld works when breaker is reset. Could it be the light switch is shorting? Why would the light come back on after restting if it was shorting the switch?
  • phredp Jun 30, 2008
    Thanks, I'll look at the switch and wiring. The thing is, the freezer is working now. But yesterday every time I opened the door, it tripped the breaker. I could reset the breaker with the door closed and it would run.
  • 161 Answers
Sounds like the switch or wiring around the switch is shorting out. Most light switches pop out with a screw driver.Some older units might have a small heater in the door around the seal but usually not See if there is any wiring going through the hinge pin. If so you can safely cut and tape this off. The door might sweat a little but this is a solution. Please deal with this as it could be a shock hazard. You might not notice if you touch and are wearing dry shoes, but a barefoot child could be killed.
Posted on Jun 30, 2008
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
How can I stop condesation building up on back wall of freezer side ? Water is running onto floor and pooling up.
Good Morning Friend,
I understand you have condensation building up on the back wall of the freezer side of your Frigidaire refrigerator, model# FGHC2342LF. I also see that this is a new refrigerator for you, and the water is pooling on the floor. It would take 24 hours for your refrigerator to stabilize at the set temperatures. First, I suggest giving it this timeframe. Secondly, if it is hot and humid, this is normal and can occur. Lastly, check with your installer to make sure that your refrigerator was installed correctly. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
Jul 08, 2014 | Frigidaire FGHC2342LF Side By Side...
Maytag MFI2269VEM2 Freezer issue. In the past two weeks, twice ice has built up in the freezer so much it is causing the fan to stop working and has been running really loud. Twice now we have taken the...
it is not defrosting. timer ,element , limit switch maybe issue. find defrost timer advance it see if compressor and fan quit running. when you advance this it should start defrost mode, which turns on the heater, which stays on till limit switch opens or timer advances, most are on 12 hour cycles
Oct 02, 2013 | Freezers
Freezer door frozen shut because of icemaker hose being dislodged
This is the best solution, wait for the repairman, by the time the door should work
Mar 26, 2013 | Siemens Freezers
I left the Freezer door open and now it seems like the freezer is not cold enough to freeze things. It has been 5-6 hours since it has been closed. Is it just taking a long time to completely cold or...
Place a glass of lukewarm water on one of the freezer shelves. Leave the freezer door closed overnight. Check the water in the morning to see if the freezer has brought the temperature down. It takes quite awhile for refrigeration units to recover from heat loads such as door open for extended periods of time.
Jan 06, 2010 | Freezers
Actually, its a True T-72 refrigerator. After running for a few weeks, the unit trips the breaker and continues to do it unless I leave it off for a few days and then re-plug it in, at which point it runs...
some manufacturers use a heater in a pan for the condensate water that is generated from the defrost cycle. It is usually located near the evap and compressor area. I've even seen them under the condenser coil. Look for a heated pan. You may have a bad heater. When it goes into defrost, water enters the pan and trips the breaker as the heater may be open and water enters it shorting it to ground. Waiting a few day allows the water to evaporate out. And the process starts all over again.
I would look for this first. If this does not pan out, let me know and we can dig alittle deeper. But try to have more details.
Dec 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
Sep 11, 2009 | True 23 cu. ft. / 651 liter Commercial...
What will cause door heaters to trip breaker.
You have a short some place isolate each component if you disconnect the heater and it does not trip the the breaker replace heater. good luck Tom
Jul 01, 2009 | Victory Freezer Freezer, Reach-In, 2 Door,...
Hoshizaki Ice Machine starting problem after shut off
I am guessing there is a safety switch somewhere which is gauging how much water is left in a defrost tray. Other likely things: open circuit breaker from the water shorting things out. Start with these. Other, more exotic things could be involved...but not as likely as the above.
Dec 04, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Nov 16, 2007 | Freezers
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
95 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
