Question about Kenwood Car Audio & Video
Very faint volume on radio.
I have a Kenwood Radio/Cassette Reciever in my 1998 26' 8" Sea Ray Sundancer Boat. The model is KRC-430, Ser. #10106035. It is the kind you can remove by pulling it out by the handle. The problem I am having is that you can barely hear radio sound coming out of any of its speakers even with the volume turned all the way up. The sound is very clear but very faint. I checked all of the speaker connections and they seem fine but was unable to check the antenna connection because I can't see where the antenna is. Every once in a while the radio will work just fine but then it goes back to what I described previously. Also, when its not working, the cassette player doesn't work either. Can you tell me what the problem is and how it can be fixed. Thank you.
  • gunbob1 Jun 28, 2008
    Thank you for your advice Dave (Tech 48). I'll let you know how I make out with this.
    President:
  • 624 Answers
Since this problem goes away sometimes, you problably have some broken solder connections in the radio. If you are very good with a solder iron this can be fixed without much problem. If not, you need to take it in to a repair shop.
There really isn't anything else that can be done. The antenna connection will not cause this problem, so you don't need to worry about that.
I hope this helps you decide how you want to handle the problem, if so a good rating would be appreciated.
Let me know if I can be any more help. I have been repairing car and home audio for over 17 years and have figured out a few things in that time.
Dave
Posted on Jun 28, 2008
I have a kenwood KRC-509S cassette and i forget the code ...??? so is there any way or any tips to open my 509S again... if u know the solution please send it to my email.
The code will only be available from your Main Dealer or by using a Radio Decoding Service who will read the working code inside your radio`s memory chip (EEPROM) using a laptop and special software
Jun 19, 2010 | Kenwood KRC-509S Cassette Player
How do i connect a kenwood krc 394 radio cassette,+ve battery, eth, and speaker connections.
Head unit color code:
12V-Yellow
12V switched-Red
Ground-Black
Illumination or Dimmer-Orange/Orange w/white stripe
Blue-Power Antenna
Blue wwhite stripe-Amp turn on
Whites-FL speaker
Greys-FR speaker
Greens-RL speaker
Purples-RR speaker
(Black stripes negative)
If you have a female harness to connect to the veicle side you will pretty much color match. The only exception is that you may only have an amp turn on wire but only a power antenna on the vehicle. In this case you would connect blue w/white stripe wire from radio harness to the blue antenna wire on the vehicle side.
If you are doing a hardwire (factory plug has been cut off) you can obtain a wiring code for your vehicle at www.the12volt.com for most vehicles.
Jun 06, 2010 | Kenwood KRC-394 Cassette Player
Kenwood KRC-2001
That's for a cd changer.
Jul 08, 2008 | Car Audio & Video
Kenwood KRC S205 Car Radio Cassette player
Depending upon the intended market, your Mazda may have been equipped with a radio for the other standard. Some radios have a switch for selection of the local channel spacing.
May 18, 2017 | Kenwood KRC-S205 Cassette Player
CASSETTE RECIEVER...(KENWOOD)KRC-585/M3
can you please find a cod for keenmood krc-585/m3
thank you
Sep 26, 2007 | Kenwood KRC-38MR Cassette Player
Kenwood krc 479r
If there was no spark and wires hooked up wrong in the first place, your player should work if you find the PWR lead and the Remote lead and ground. Then speaker wires +) and (-
Sep 25, 2007 | Kenwood KRC-479R Cassette Player
Car Audio & Video Logo
97 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
