Question about SanDisk Sansa e260 MP3 Player
Sansa Updater Problem
I tried to run the updater program with my e260, but it crashed. Now my PC will not recognize the e260. I tried to remove the updater program from my computer, but when I try to run the removal it stops and says
failed to stop sansa dispatch error
Any suggestions on how to remove the updater program?
Jesse
Let me know if you have a solution at
jsilver41@earthlink.net
  • 8,596 Answers
Use the add/Remove hardware tool first
If that fails, go into Programs --> Sansa --> Uninstall
That's a new one for me - go ahead and call Sansa
Posted on Jun 28, 2008
My sansa san disk mp3 player wont turn off when not connected to pc. when it is connected it keeps going from saying connected, disconnected and writing all in seconds. when it is connected to the pc it...
First lets try resetting your player, to reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Next; if that does not help click on this link and down load the Updater program and update the players firmware.
http://kb.sandisk.com/app/answers/detail/a_id/156
Oct 16, 2010 | SanDisk Sansa e260 MP3 Player
My sansa e260 says load main screen fail switch to recovery mode...what do i do?
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic go to /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa.
http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related
here is a link to a kid showing you how to go to recovery mode.
Update software from this link..
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
and install the software before you recover
Usb mode in settings MSC is best, Updater recognizes it in this mode
Jun 26, 2010 | SanDisk Sansa e260 MP3 Player
Hi! I have the same problem wich was commented about the refreshing database screen with my sansa e260 v2, but the supposed solution is i have to turn hold button on, then keep pressing rec, then turn mp4...
Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually...
here is a link to a kid showing you how to goto recovery mode.
Jun 15, 2010 | SanDisk Sansa e260 MP3 Player
I hav a sansa e260 player it was working just fine until recently the screen is just blank and only the ring glows .my pc doesnt recognize the device please help
Download the converter after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard2.gif).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Set sansa to recovery mode, Start the updater plug the sansa into the computer, unplug when told sansa, should restart (Lock sansa press and hold rec and menu until recovery begins)
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
Go to my computer click on folder scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders Right click on your sansa then format a couple of times hope this works
Oct 22, 2009 | SanDisk Sansa e260 MP3 Player
Can't access files on Sansa e260
I had to install the update on to my labtop and finally it recognized it and updated....
Download Update if you haven't yet on a flash drive for the labtop definite 2.0 usb port... (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
Apr 21, 2009 | SanDisk Sansa e260 MP3 Player
Will not turn on black screen with faint song that was playing on black screen frozen computer not recognizing when plugging in to USB it was lightly dropped
Reset All
will be gone.....
IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
Apr 16, 2009 | SanDisk Sansa e260 MP3 Player
Sansa updater does not recongnize e260
Make sure USB mode is MTP....If this doesn't work make sure that you are connected to a 2.0 USB port....I had to install the update on to my labtop and finally it recognized it and updated
Apr 11, 2009 | SanDisk Sansa e260 MP3 Player
How do i update my firmware
It is pretty easy. If running Windows just download the Sansa Updater (see link below) and install it.
Then, use the Mac/Linux instructions (even if running windows!) to put the e260 into MSC mode- turn e260 on, switch e260 hold switch to on, press and hold the e260s LEFT button "<<" while you plug the USB cable into the e260.
For me (running Windows XP) the Sansa updater automatically detected the e260 then and updated the e260's firmware.
Links to the updater, and alternative complete instructions for Mac/Linux are here
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=10357
Sep 07, 2008 | SanDisk Sansa e260 MP3 Player
Videos
You need to use the sansa media converter program that came with the sansa on the CD. This is used for photos1.gif and for video. The supported files are listed on the screen once you open it.You shouldnt have any problems transferring music to it using that program
Jan 25, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 says connected but device not recognized
I agree with the above suggestion. Try setting the USB Mode under "Settings" on "MSC" on the Sansa. My computer would not recognize the e260 when the mode was set to "MTP"; works fine on "MSC".
Dec 27, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
429 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Sanath Kumar V
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
