Question about Motorola Mobility H500 Wireless Headset
Bluetooth module not attached
My bluetooth was paired with my raZr and working fine and then one day when I tried to use it, it wasn't paired up with my phone anymore. I tried going into the bluetooth link to go through the setup process again but it says "bluetooth module not attached" and it won't let me go any further to the setup menu to reconnect it. How do I reconnect it if it won't let me?
  • 2 more comments
  • spider1983 Jul 07, 2008
    I had my h500 connected to my sony ericsson. since then I have changed phones and my new phone will not pick up the ear piece. How can I fix it?
  • Anonymous Aug 04, 2008
    I had the same problem. On Aug 3rd, 08, my bluetooth was connected to my phone I was going up the mountain and the bluetooth disconnected itself. I didn't try to reconnect since I wasn't driving, but the next morning when I tried to connect I got the same message "bluetooth module not attached" on my phone . I was able to fix it by simply taking out the battery and then just putting it back in place. When I turned the phone on the bluetooth was reconnected. I've tuned the bluetooth off and on a few times just to make sure it was working properly and is. Hope this helps. (jawbone bluetooth)
  • Anonymous Feb 06, 2009
    I have a H500 that can be found and added to "My Devices" but after finding it, my phone will not connect.....It tries but then says connection failed....again this is AFTER I search and add device. It finds the H500 but after adding it will not connect. I tried the same H500 with another phone and it finds the device as well but will not connect. Anyone have any ideas?
  • Anonymous Mar 28, 2009
    it is really annoying, i dont have the same type of bluetooth but same problem
  • 679 Answers
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
Bluetooth quit connecting with Moto Razr Phone
Go to bluetooth and see what is listed click on it and remove device. Start over.
May 03, 2017 | Motorola Mobility H700 Wireless Headset
Moto razr3v bluetooth system doesn't work
probably pairing problem. You need to pair your bluetooth with the phone again. There are video instructions on the exact steps on www.HandBookLive.com under Electronics category (Bluetooth)
Mar 01, 2009 | Motorola Mobility RAZR V3
BLUETOOTH MODULE NOT ATTACHED
you need to switch on bluetooth headset with battery charged enough. also you need to put bluetooth in search mode to pair it with phone. see manual which came with bluetooth to get it in search mode.
Jan 01, 2009 | Motorola Mobility RAZR V3
I succesfully pair my RAZR V3 with H350 Bluetooth from Motorola
I got home last night and there is e-mail from Motorola Tech. Support answering my same question.
I am very happy because the solution is very simple I can do by myself.
It said: remove the battery for view second and put it back,.............. wunderbar it works and Motoblue is together again for long time hopefully.
Regards,
Motoblue
Dec 10, 2008 | Motorola Mobility RAZR V3
I lose my Bluetooth connection, and the problem is with the phone
You will need now to take the phone and have the firmware reflash in the phone.
Bluetooth pairing on Motorola Razr V3
try to check the setting of your blutoot, check te find me option.
Jun 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Bluetooth module not attached !
try this,., delete old pairing for ur bluetooth, and re- pair it again...gudluck
May 10, 2008 | Motorola Mobility RAZR V3
Bluetooth Pairing with Motorola Razr
try to do this.. go to menu, settings, inittial set up, master clear, code (000000) the fone boots w8, then again go to menu, settings, initial set up, master reset, code (000000) fone boots again w8, .. then try to pair it again,.,, goodluck man!
Apr 28, 2008 | Motorola Mobility RAZR V3
Bluetooth problem
try resetting the phone and pairing the device again and see if that helps.
Mar 12, 2008 | Motorola Mobility RAZR V3
Motorola h500
Delete it from your Razr, turn off the bluetooth and recharge it to full. Try pairing it again. Make sure you enter the passkey correctly. Check the manual for the bluetooth if you dont know what it is. It is usually 0000.
Dec 30, 2007 | Motorola Mobility Bluetooth Hands Free...
Motorola Mobility H500 Wireless Headset Logo
305 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
