Question about Carrier 38CKC042 Air Conditioner
Model number for Carrier furnace with issue for blower 5 minute off delay
Thanks-the generic info was much more than I had already-the model number for my furnace is CK3BXAO48021AAAA. I appreciate ALL of your helpful info.
    Novelist:
    Champion:
  • 230 Answers
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Posted on Jun 27, 2008
My bryant furnace fan will not turn on. Everything is sequencing, the induction fan starts and the flame lights, but the fan will not turn on. The capacitor reads 4.86 uf. Any suggestions?
Your fan delay relay is not functioning. On most furnace fan controls, there is a fan delay relay that delay the fan from turning on until it senses the temperature increase, typically around 130 degrees. once the relay senses the temperature increase it closes a contact inside the sensor and turns the blower on. It is the same device that keeps the fan running once the furnace turns off. Just take the Model number and serial number to your local dealer and get a fan delay relay and replace it.
Dec 07, 2014 | Bryant Heating & Cooling
2004 Keeprite High Efficiency Furnace won't heat.
Do you have the model number? There is a problem with either the blower motor sensor or the ignitor. When the furnace get a signal for heat, the blower motor comes on and then the ignitor. If either one of those fail then it stops, waits and tries again. When the tech was there, if he did not replace any parts then he did not do his job. You can call them back out because the issue was not resolved or you can post the model number for us.
Nov 04, 2017 | Heating & Cooling
Furnace is a Rudd UGEB model. Burners ignite and but the blower (squirrel cage) doesn't start. After a couple minutes they turn off and the blower starts and runs for less than a minute and shuts off....
Sounds like the fan limit was not replaced correctly. You can try switching the blower to the On position (instead of Auto), if the furnace runs properly with the blower on that would be the most likely culprit.
Sep 24, 2011 | Ruud UBHC Air Conditioner
What are the carrier 8000ts led error codes?
They are listed inside the front panel of the main unit.
LED CODE
EACH OF THE FOLLOWING STATUS CODES IS A TWO DIGIT NUMBER WITH THE FIRST
DIGIT DETERMINED BY THE NUMBER OF SHORT FLASHES AND THE SECOND DIGIT BY
THE NUMBER OF LONG FLASHES.
STATUS
11 NO PREVIOUS CODE - Stored status code is erased automatically after 72
hours. On RED LED boards stored status codes can also be erased when power
(115 VAC or 24 VAC) to control is interrupted.
12 BLOWER ON AFTER POWER UP (115 VAC or 24 VAC) -Blower runs for 90
seconds, if unit is powered up during a call for heat (R-W closed) or R-W opens
during blower on-delay.
13 LIMIT CIRCUIT LOCKOUT - Lockout occurs if the limit or flame rollout switch is
open longer than 3 minutes.
- Control will auto reset after three hours. - Refer to #33.
14 IGNITION LOCKOUT - Control will auto-reset after three hours. Refer to #34.
21 GAS HEATING LOCKOUT - Control will NOT auto reset.
Check for: - Mis-wired gas valve -Defective control (valve relay)
22 ABNORMAL FLAME-PROVING SIGNAL - Flame is proved while gas valve is
de-energized. Inducer will run until fault is cleared. Check for:
- Leaky gas valve - Stuck-open gas valve
23 PRESSURE SWITCH DID NOT OPEN Check for:
- Obstructed pressure tubing. - Pressure switch stuck closed.
24 SECONDARY VOLTAGE FUSE IS OPEN Check for:
- Short circuit in secondary voltage (24VAC) wiring.
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than
five minutes, inducer shuts off for 15 minutes before retry. Check for:
- Excessive wind - Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Restricted vent
- Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used)
If it opens during blower on-delay period, blower will come on for the selected
blower off-delay.
33 LIMIT CIRCUIT FAULT - Indicates a limit, or flame rollout is open. Blower will
run for 4 minutes or until open switch remakes whichever is longer. If open
longer than 3 minutes, code changes to lockout #13. If open less than 3 minutes
status code #33 continues to flash until blower shuts off. Flame rollout switch
requires manual reset. Check for: - Restricted vent
- Proper vent sizing - Loose blower wheel - Excessive wind
- Dirty filter or restricted duct system.
- Defective blower motor or capacitor. - Defective switch or connections.
- Inadequate combustion air supply (Flame Roll-out Switch open).
34 IGNITION PROVING FAILURE - Control will try three more times before lockout
#14 occurs. If flame signal lost during blower on-delay period, blower will come
on for the selected blower off-delay. Check for: - Control ground continuity
- Flame sensor must not be grounded
- Oxide buildup on flame sensor (clean with fine steel wool).
- Proper flame sense microamps (.5 microamps D.C. min., 4.0 - 6.0 nominal).
- Gas valve defective or gas valve turned off - Manual valve shut-off
- Defective Hot Surface Ignitor
- Inadequate flame carryover or rough ignition
- Green/Yellow wire MUST be connected to furnace sheet metal
45 CONTROL CIRCUITRY LOCKOUT Auto-reset after one hour lockout due to;
- Gas valve relay stuck open - Flame sense circuit failure
- Software check error
Reset power to clear lockout. Replace control if status code repeats.
If status code recall is needed, briefly remove then reconnect one main limit wire to display
stored status code. On RED LED boards do not remove power or blower door before initiating
status code recall. After one status code recall is completed component test will occur.
Thanks for Choosing FixYa.
Kelly
Oct 05, 2010 | Heating & Cooling
What is the part number for a blower wheel on a carrier furnace model FC4BNF030
Measure blower wheel or take it to AC parts house and they will match it for you. Blower wheels are pretty generic.Rusty
Jun 05, 2009 | Heating & Cooling
48DD0284 model I am wanting a part number for a Time delay relay. Dont know how to look up
I looked up information and the unit is obsolete. I also did not see a time delay in the diagram with the original unit. It must have been added later. Post me back and let me know where it goes and what numbers it has on it.
Nov 28, 2008 | Carrier Heating & Cooling
Model number for furnace
Great! That is it. Now you have the model numbers for all of your hac equipment.LOL. Anyway I do have this manual and I an send it to you via email if you like. It shows the jumper that I told you about as well as a picture of the circuit board and instructions on how to change the blower delay. Just shoot me an email. Good Luck!
Don,
cservice@square1hvac.com
Jul 03, 2008 | Carrier 38CKC042 Air Conditioner
Furnace model number
I believe I have the manual for this unit. Just shoot me an email and I will send it to you. It describes in detail how to do this blower off delay.
Don,
Jul 02, 2008 | Carrier 38CKC042 Air Conditioner
5 min time delay for central system blower unit not reset whe serviced
Make sure to turn off the furnace at the breaker or disconnect switch before attempting to touch the electronics of the furnace. Also look around the furnace for an owners manual. The manual will have the process for changing the blower off delay. I have given you a pretty generic process below. If you need more specific directions I will need your model and serial number. If your furnace is new enough I may be able to find your manual in our system. Good Luck:)
In most cases a circuit board model will have a small (1/4 inch x 1/8 inch) black, plastic jumper. I think I remember that some can be red also. Anyway This jumper is plugged on to two vertical prongs coming from the board. There are other bare prongs on either side of the jumper. If you look at the writing on the board you will see different numbers ranging from 60 to 190. These numbers represent seconds in time. You can change this jumper to match the seconds that you want for the blower off delay.
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
How to reset 5 minute blower delay for carrier 4 ton central system-instlalled 1995
There are potentially 3 time delay relays in this system.
1) Many digital Thermostats come with compressor ON delays that are not serviceable.
2) There is an accesory manual Time delay available for this unit. It is also a compressor ON delay. (located in the electrical compartment of the condenser)
3) Most newer furnaces have a blower OFF delay (set manually at the circuit board.
I have the technical manual for this unit if you need it.
Jun 25, 2008 | Carrier 38CKC042 Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
259 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
