My acer lcd monitor of 18.5 inch is two lines problem
It depends, if the lines are due to physical damage then the warranty is no good if the screen is faulty the your fine. the way to find out is if you apply a little bit of pressure to the line and it gets bigger then its physical, if not get your warranty out
Use the warranty before it expires, and you are stuck with a costly repair bill
