Question about Sony PlayStation 2 (PS2) Console
System Configuration I can only get to the system configuration screen. I have never dropped it/abused it in any way. I was playing it and it just stopped, now it will only get to sys. config. screen. What's the deal?
    Problem Solver:
  • 18 Answers
How long have you had the PS2 and how long has this been happening? This link was the same things i did when my PS2 wasn't working quite well. Hope this link will help out alot!
http://arstechnica.com/articles/paedia/hardware/ps2.ars/3
Posted on Jun 28, 2008
Backup the configuration of fortigate
Administrators can back up the FortiGate unit's configuration file from the System Information widget. Select Backup in the System Configuration row, to back up the firmware configuration file to a local computer, USB disk or to a FortiManager unit.
You should always back up your configuration whenever you make any modifications to the device configuration or performing any firmware updates or changes.
Local PC Select to back up the configuration file to a local management computer. FortiManager Select to back up the configuration file to a FortiManager unit. The Central Management settings must be enabled and a FortiManager unit connected with the FortiGate unit so that the FortiGate unit can send the configuration file to the FortiManager unit.
To enable central management, go to System > Admin > Settings. USB Disk Select to back up the configuration file to a USB key that is connected to the FortiGate unit. Full Config Select to backup the full VDOM configuration. This appears only when the FortiGate unit has VDOM configuration enabled. VDOM Config Select to backup the only the VDOM configuration file. This option backs up only the configuration file within that VDOM. Select the VDOM from the drop-down list, and select Backup. Encrypt configuration file Select to enable a password to the configuration file for added security. Password Enter the password that will be used to restore the configuration file. Confirm Re-enter the password.
Feb 14, 2014 | Fortinet, Inc. FortiGate 80C (FG80CBDLUS)...
Picture on my lap top screen keeps dropping down,when i am playing games..can I stop this.
You might wanna terminate the process that causes that picture to drop down frequently.
Goto : Start > Run
Type : msconfig
Press : Enter
Now you should see the System Configuration Utility.
From here, open the "startup" tab and disable any possible/unwanted program that you think is causing trouble.
Restart your computer & Voila!
#Alternative
Press : Ctrl+Alt+Delete to open Task Manager
Under the processes tab, find the process (if you've identified) it and click on "End Process"
Tip : Window Title is shown on the right side of the process.
Feb 13, 2013 | Microsoft Windows 98 for PC
How to enter bios on thinkcentre 8811-6cu
Try hitting F2 when boot starts will normally take you to the bios.
Jun 14, 2011 | Lenovo ThinkCentreĀ® M55-8811 PC Desktop
COMPUTER WAS TURNED OFF IMPROPERLY. TURN-ON WAS IN SAFE MODE NOW EVERYTHING IS LARGER AND BLURRED
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
always click APPLY after making any changes
don
Feb 02, 2011 | Computers & Internet
Hi, whenever I put a dvd on my Dell Inspiron 1545 laptop there's a msg comin sayin : ''This application cannot play the dvd because of the current output display configuration. Try restarting the player.''...
could be faulty graphics or incorrectly configured screen resolution goto manufacturers site to find correct configuration.Also go into bios and see your system specs ,you might be able to see any technical fault here (F2 whilst booting)
Oct 23, 2010 | Computers & Internet
Output display configuration
Try changing the display resolution of your system. To do this, follow the instructions below: Right click on the Desktop - Properties - Settings - on the screen resolution, drag the slider to the left or to the right to adjust, and click apply, and check the player before you click Ok. Repeat this steps until it's is playable. I can't help you perfectly since you didn't mention the operating system you are using. Good luck. Thanks for using FixYa.
Jun 02, 2010 | CyberLink Power DVD DX 8.0 for PC
Browser shows no data on PlayStation 2 Console
I am having the same problem with my PS2, but I have an HDD inside of mine. I am told this is a circuit problem inside the PS2 that doesn't allow the information to be transfered to the RAM. That's why you see “No Data” instead of the usual problem of “Disc Read Error”. I hate to say it, but it sounds like you are going to have to do the same thing I am about to do. Send it in to Sony and get it repaired.
I am also pretty sure this PS2 you are talking about is the large fat one, and not the slim one.
Sep 03, 2008 | Sony PlayStation 2 (PS2) Console
Screen says browser system configuration
do you have memory cards with system configuration on them??
Aug 30, 2008 | Sony PlayStation 2 (PS2) Console
Cursor lockup
This just because that there are too many services running in the background of the Operating system
All you need to do is to manually disable maximum of them and disable all the startup Items
Here is how you can do that the easy way
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Microsoft Windows XP Home Edition
WiFi query
    First DS (system you are transferring the ID from)
  1. Turn on any Nintendo WFC-compatible game and access the WFC Setup Utility. (Consult the game manual for the game you are playing for specific information.)
  2. Tap "Options."
  3. Tap "Transfer Nintendo WFC Configuration."
  4. Tap "Ok", then tap "Ok" again.
  5. Second DS (system you are transferring the ID to)
  6. Remove all games from the DS you wish to transfer the settings to, then turn the system on.
  7. On the DS's main menu, select "DS Download Play."
  8. Select "Nintendo WFC Configuration Transfer."
  9. Tap "Yes" when asked if you want to download the software. The word "Downloading..." will appear.
  10. First DS
  11. On the DS with Nintendo WFC configuration, tap "Ok" to confirm that you wish to transfer the configuration.
  12. Second DS (system you are transferring the ID to)
    • If there is an existing configuration on the new DS, tap "Ok" to confirm that you wish to overwrite the existing configuration.
    • Once the transfer begins, it will take about half a minute.
    Both DS Systems
  13. Once the configuration has been transferred, tap "Ok" to save the changes and shut each system off.
All of the Friend Codes you had given or received on the previous Nintendo DS will now work in the Nintendo DS system you transferred the ID to.
I just copied that from nintendo.com's customer service for you... it's better than how I could explain it.
Oct 22, 2007 | Nintendo DS Lite Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
