Question about Kenmore Elite 45986 Front Load Washer
Mildew My front loading Elie has mildew growing inside of the large door gasget. How can I clean it?
  • Jaydub2 Jul 22, 2008
    I am having a similar problem....I just noticed brown spots and smears on random pieces of recent white loads - almost looks like old blood smudges, but it's not. I think it may be either brown mold coming out of the gasket, or, gasp: rust. I'm going to go look at what may have accumulated in the gasket and remove it. I also plan to take a bleach-soaked rag and wipe out the channel in the gasket. Hopefully I'll catch whatever may be lurking. Can't figure out what else this might be....
    Genius:
  • 1,028 Answers
All front loads all brands have same issue with mold people today tend to use less bleach CHLORINE BLEACH that is ..allow machine to fill with hot water normal wash pour 2 cups CHLORINE BLEACH in water allow to wash a few min to mix open door and with cloth wash inside of door gasket be sure to roll gasket back and wash underneath lip allow to finish complete cycle should remove most of mold try to this every few months..also leave door open between use to allow moisture to dry out as much as possible like i said YOU ARE NOT ALONE
Posted on Jun 28, 2008
I getting a funky smell in my laundry room and bathroom, but only when I am doing laundry. I am wondering if it has something to do with the hose. Its be like this for about six months.Thanks
It probally mildew growing inside the wash tub and associated water connnections like the pump housing, drain hoses. Mildew growth is common problem with front load washers. You can try to reduce the occurance of mildew by leaving the door and soap dispenser door open when not in use. Also wipe with door gasket with a rag to dry it.
To kill the mildew in the machine wash an empty load with hot water and vineagar about once a month. Repeat as neccessary. There other products to help reduce mildew such as affresh. Hope this helps you.
Aug 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clothes smell mildewy after washing and drying
This is a common problem with front load washers. Mildew tends to grow in these washers due to it use of less water than top loaders, often leaves dirt and soap residue on the machine. To help prevent mildew, wipe the door gasket, leave door and detergent dispenser open after wash. Wash once a month empty, with hot water and vinegar to kill the mildew in the machine.
Jul 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is the issue with mildew and how do I address it? My laundry never smells clean
Any washing machine will grow mold & mildew when there is moisture in it and the door is shut. When you do a load of wash, the smell transfers to the clothing. To eliminate it, run a load just water & chloring bleach. This will kill the spores. Adding a little color safe bleach to each load or leave the door open when not using the washer will keep the problem from coming back.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We have mildew in the rubber gasket behind the front door
use a good mildew cleaner on gasket the gasket gets wet from when clothes are taken out and drip on gasket mildew grows on damp/warm surfaces
Sep 26, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Smell of mildew on our towel and sheets
This is probably happening because the clothing is being left damp in the washer. When it is warm during the summertime mildew will grow very quickly in the towels. On front load washers you need to leave the door open when not in use to keep mildew from growing. You should wipe out behind the inner seal any moisture when you are done doing laundry. This is an issue for most front loaders. Some front loaders have a clean washer cycle that uses bleach to sanitize the drum. Other washers like the Samsung have a block of silver and release silver ions in the wash to sanitze the clothes.
Sep 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mildew inside bellow.
is this a question? I will assume that you are saying that there is mildew growing below something, possibly the drum, inside the washer. The only way to definately get it out is disassembly and thorough cleaning. Check your discharge hoses to make sure they are not clogged, leaving water in the washer rather than discharging all of it. If you want to kill the mildew/smell, run an empty load or just some rags but throw a cup or two of bleach in the washer. The chlorine will kill the mildew growths. Run a rinse cycle or two before your next load of darks to get the chlorine out (especially if you are having a discharge problem) so you don't inadvertantly bleach your clothes.
Aug 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Allways smells like mildew when open up
Yup, my front loader has the same issue. I found the rubber seal around the door has a fold in it that holds water and sometime candy wrappers and various stuff from pockets.
By wiping the fold in the seal out on occassion and not closing the door in between uses, the issue was resolved.
Jul 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Odor coming from inside washer
There is a tub beyond the tub you see. Run a load of water with chlorine bleach. This will kill the mold & mildew spores that are causing the odors. ****Do NOT add clothing to this washload****
If possible, keep the door open when not in use. This will allow the inside to dry and mold & mildew cannot grow.
Jul 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Mildew on rubber gasket around door.
This happens when you keep the door shut. Run an empty load with extra chlorine bleach to kill the mold spores. Keep the door open to prevent mold or mildew from growing again.
Mar 18, 2009 | LG WM-2277HW Front Load Washer
Mildew
allow the drum to air dry ,thats by leaving the door partially open.You will see a huge difference.And yes ,all the time.
May 26, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Kenmore Elite 45986 Front Load Washer Logo
152 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
