The humming you hear is coming from the motor,unfortunitely the motor needs to be replaced,when the motor heats up it shuts down from running hotter than normal,could be from not cleaning out the dryer every one to two years,the lint covers the motor like a blanket making it run hot,the vent line cloggs up and the duct that the lint filter slides into needs to be cleaned out,also it could be from to large a load put into the machine but whatever the cause you need to replace the motor or replace the dryer depending on how old it is and what shape it's in.next time send the model number,i can look up your part and tell you how to change out the motor
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
