The wolfgang puck slow cooker uses duel heating elements one on the bottom and also around the sides. The temperature is controlled by the user. I would double check the setting you had this on, but I believe that the better quality cooker simply does a better job than most of the cheaper store models and therfore you get better results. this cooker also automatically goes to low mode when the food is done, did yours switch to the low mode, or did it stay on high? To answer your question, the cooker does not intentionally cook at higher temps, but the compitition just doesn't match up to the quality in this unit. I have read many testomonies from many happy customers about the quality and ease of operation and the cooking abilities of this machine. It just may be that you wil have to get accustom to the way this cooker works.
I hope this helped and if you have any more questions about this I would be happy to try and answer them for you.
2007 Ford edge shifting out of park
my 2005 honda crv negative battery terminal was disconnected for about two minutes, after reconnecting the negative terminal back to the battery, the ac compressor no longer cuts in, I was told the computer may not be recognizing the ac system and that can happen sometimes when negatively terminal is disconnected, what can I do to get computer to recognize ac system?
