Question about Dishwashers
Diagram for ldf7811 st dishwasher - Dishwashers
I got help fm Benimur through your expert service. I am satisfied but where do I post my review? Can't seem to find a location. Do I post it in my chat session?
Posted on Jun 28, 2008
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Help with cb radio
Hello there
here is a link for the scematic ok?
best regards michael
  1. Cobra 29LTD ST, 29WX ST 29LTD ST Owners Manual. 29WX ST Owners Manual. DIAGRAMS. 29LTD ST Schematic Diagram ... WX Schematic Diagram. 29LTD, 29LTD ST, 29WX ST Factory Service Manual ...www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/index.htm - Cached
Sep 15, 2009 | Cobra 29 LTD CB Radio
Dishes stay greasy
On this LG LDF7811 dishwasher, are you getting any error coded in the display?
If no, buy a small box of name brand dishwasher detergent powder (like cascade or electrosol) and use it for two loads, but do not over fill the soap dispenser cup.
If problems continue, it is time to clean everything under and in the filter assembly that is below the lower spray arm (silver phillips screws.) Search for any debris.
Please report back what you find, and we can take the next step, OK?
Sep 13, 2009 | LG 24 in. LDF 7811 Stainless Steel...
After cycle completes there are small pieces of debris over the dishes. I have ran the dishwasher cleaners through but no help.
The LG LDF7811 Dishwasher is a water and energy conserving unit. So, anything the obstructs the wash pump reduces its ability. here are some steps to follow:
1.) Buy a box of brand name dishwasher detergent powder (e.g. Electrosol or Cascade) Use it and avoid generic powders and never use gels or tablets in any dishwasher.)
2.) Remove the lower basket and then the lower spray arm (pull it up and out firmly)
3) Remove the approximate 9 phillips screws from the filter assembly beneath where the spray arm was. (Take a digital picture of each stage, so you can reassemble later.)
4.) Rinse/wash everything, especially the filter "orb" with the mesh panels, as best you can.
5.) With a flashlight, inspect the sump area that you just exposed. Watch out for broken glass! Remove all debris and look one more time for any little chunks that may be blocking stuff down there.
6.) Inspect the impeller, looking for damage, being plugged. Make sure it spins freely, but is also securely fastened to the top with the screw.
Reassemble the dishwasher and test.
Please report back with what you find. OK?
Thanks and Good Luck!
Apr 15, 2009 | LG 24 in. LDF 7811 Stainless Steel...
LG Dishwasher LDF7811 Making Growling Noise
Recommendations:
-Switch to a brand name detergent powder - like Electrosol or Cascade and do not fill the dispenser cup full. You will notice the difference immediately.
-Remove the filter assembly one more time and inspect underneath with a flashlight. Look closely for debris and also inspect the impeller to look for damage and that it is spinning freely.
Reassemble and listen for the growling sound. It should not happen. If it continues, you may have a a failing wash motor / motor bearing.
Please report back what you find. OK?
Apr 11, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
LDF7810BB LG dishwasher won't run
Confirming that this is an LG LDF7811 (which happens to be black) ... What you are seeing is a error code "tE" as in thermal error.
(The mentioned drain error would be "OE" as in Outlet (Drain) error.)
First check (with a thermometer) the inlet temperature of the hot water. If it is greater than 140 degrees, turn down your water heater to no less than 120 degrees and retry.
If problems persist, the problem is probably the thermister.
If it is not a failed thermister, then the controller card (PCB) needs to be replaced. Neither are easily changed and I urge you to contact LG service for repair. (See your manual for the number)
Good Luck! and please report back with what worked.
Mar 19, 2009 | LG LDF6810 Built-in Dishwasher
LG dishwasher doesn't heat water
I had the same issue with my LDF7811 about 2 years into its life. I replaced the heating element and that took care of it. Not a terribly difficult job, but it will require removal of the dishwasher and dismantling it from the underneath.
Dec 18, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dirty dishes on lower rack
Please confirm that you own an LG LDF7811 dishwasher and it is not cleaning properly.
-Are you getting any error codes displayed? -Did you remove the mesh filter and clean any debris beneath it plus rinse out the filter itself?
-Are you using a name brand diswashing powder? Avoid ultra-cheap detergent, especially in water-conserving units like the LG 7811. Never use DW gel or tablets in any dishwasher.
-Do not over rinse the dishes before placing them in the DW. The food granules actually are used to clean all the dishes before being rinsed away.
Please try these suggestions and reply to this message with what worked best and if the problem continues. Good Luck!
Aug 25, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
123 people viewed this question
Top Dishwashers Experts
