Question about HP iPAQ hx2190 Pocket PC
Ipaq hx2190 My recently purchased, second hand, Ipaq hx2190 keeps switching itself on and draining the battery. It's driving me nuts! Any ideas please?
Hard reset for hx2190
Posted on Aug 23, 2008
Toyota Yaris 2001 batter keeps draining out - Multi information display clock and temperature stays on even after taking the ignition key out and could be a probable culprit but dont know how to switc
MAYBE THERES AN ALARM SYSTEM DRAINING BATTERY
BEST WAY TO CHECK IS REMOVE BATTERY LEAD ,AND WTH EVERYTHING TURNED OFF SHOULD BE NO SPARK WHEN YOU RECONNECT
Oct 11, 2012 | 2001 Toyota Yaris
Tip
Thanks!! I've tried with a Alcaline battery 9V+ aluminium wire (I didn't want to...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Jan 04, 2009 | Cingular Wireless 8125 Smartphone
I have an hp ipaq the model is hx2190 and i have no clue how to get a wifi internet conection?
Via the PC your IPAQ talks to your PC / Phone by Bluetooth and shares the internet connection it does not connect direct to the internet
Jan 20, 2011 | HP iPAQ hx2190 Pocket PC
USB connection to PC problems
You must have ActiveSync installed and running on your WinXP PC, for a WM device to be allowed to synchronize its data. Just in case your PC happens to be missing it, you can download it from this location.
Hope it works for you.
Cheers! Carlos
May 09, 2010 | HP iPAQ hx2190 Pocket PC
HI I NEED A ACTIVATION CODE FOR A PDA WITH TOM TOM 5 NAV GREAT BRITAIN PLUS MAPS THANKS
Hello Sir / Madam
Greeting and Congratulation to you and all friends of your company Sir i have a little problem and am pleading for your help i cant setup my Phone and i need the manual Please
Oct 13, 2008 | HP iPAQ hx2190 Pocket PC
I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF...
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
May 10, 2008 | Computers & Internet
Power failure IPAQ4350
It can be problem with the battery may be it is lose or  change the battery of ur mobile try then
Gizmo1
Oct 19, 2007 | HP iPAQ H5555 Pocket PC
IPAQ turns itself on
Go to the ActiveSync options of your pocket pc and to go to Mobile Schedule and choose "Manually". I think it's set to sync automatically in a few minutes that's why it turns itself on.
Sep 11, 2005 | HP iPAQ HX2100 Pocket PC
HP iPAQ hx2190 Pocket PC Logo
348 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
