Question about Olympus D-535 Zoom / C370 Zoom Digital Camera
D-535 zoom i put in new batteries, and now when i turn it on,the lens extents and then retracts and thats it--the monitor doesnt even come on.
  • shannen77 Sep 03, 2008
    I have the same problem! I can't get the thing to stay on or show anything on the screen it just keeps retracting a couple times then turning off!
    Master:
  • 377 Answers
Try to remove the battery for an hour.. then put it back again.. then charge the battery at least 3hours..
Posted on Jun 27, 2008
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
Lens won't retract
You could try to gently pull the lens straight. If it's leaning to the right then pull the lens to the left. Don't use brute force but it's possible to realign the lens this way. If it works you'll hear a click and the lens will look straight. Switch on and see if it retracts. I'd only use this as a last resort because you can cause additional damage if it's overdone. It has sood success rate also
Sep 06, 2009 | Pentax Optio M20 7MP Digital Camera with...
Lens will not retract after being
the problem is that the lens is out of alignment. if its not making grinding sounds try manually help the lens to reseat itself. if that doesnt work its not ecomical to repair unit cuz parts and labor are about 120-130 dollars.
Jun 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
No power on olympus D-535
Did You try to reverse the battery's (Put the left battery on the right side and etc)?
Oct 30, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Olympus D-535
well..remove the battries again ..and re insert the battries...
while inseting the battries ensure that u follow the steps given below..
Make sure camera is turned off
The monitor is turned off.
The green lamp and orange lamp on camera is off.
The lens is not extended.
Jun 04, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Olympus C-370 LENS GOES OUT, IN AND SHUTS OFF
It is possible that a flexible circuit connector has loosened. This can be checked by removing the covers, DISCHARGING THE CAPACITOR. (The large, black, cylinder beside the lens.) Remove the black Phillips screws holding the LCD and main circuit board and then carefully lifting the circuit and checking the large connector on the back of the main circuit. BE CAREFUL! It is easy to break the flex. The other, most likely cause is the failure of the Photo Interrupter in the lens. The only solution is to replace the lens and reprogram the camera.
Sep 18, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
Camera has locked down!!!
resetting may help solving the problem. in order to reset your Olympus Digital Camera, please follow the instructions provided below: 1. Remove all cards, cables, etc. 2. Remove the lens cap or slide open the lens cover and turn the camera "ON" in any of the record modes. Then remove the batteries. 3. let the camera sit for approx. 5 to 10 minutes 4. Re-insert the card and a fresh set of batteries or an AC adapter 5. Test the camera I hope this will solve your problem.
Mar 29, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
Olympus D-535 Zoom / C370 Zoom Digital Camera Logo
57 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
