Question about Sharp Office Equipment & Supplies
Sharp AR-M355 copier with AR-EF3 adf
Only on the last sheet it will jam. Will pull it part way through and stop.It just gets pass the registration roller. Machine has only 32,000.I have tried replacing the paper pick up roller,paper feed roller and the gate solenoid.
With what you described it sound like the paper out sensor is not working properly, might be bad or broke. Hope that Helps... Lbcoaster
Posted on Jun 28, 2008
I need "Sharp AR-EF3" driver for win 7, what's the similar Driver for this product? EF3 doesn't exist in Sharpusa.com Thanks in advance
Plug The scanner in. Go to control panel/device manager (in win7, win8) look for you new unknown device (anything with a yellow exclamation point). Right click it and choose update driver (allow it to search the web)
Oct 18, 2013 | Sharp Ar-ef3 Scanner Module With Radf For...
Sharp copier
1) turn machine off or on
2) get a flashlight and look for torn pieces of paper wedged anywhere in the paper path
3) clicking indicates that something is trying to turn but cant because it is stuck
4) dust on a photo sensor
5) broken flag that activated the photo sensor
6) look for turn knobs or release tabs that will let you ease paper out of the machine. Yanking on the sheet with brute force is always a bad idea because the sheet tears and always leaves something behind to get stuck
Aug 23, 2012 | Sharp AR-150 Toner
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
AR-M355 Latent copies.
This make is not my specialty, but if the fuser's been replaced, then it can only be a drum cleaning issue causing that problem.
Dec 28, 2009 | Sharp AR-M355N Copier
Paper tray will not go up or down. Cannot get it to move.
Sharp AR-650 Код ошибки Подкод Описание C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 19, 2009 | Sharp AR-650 Copier
When using the adf get error message
Advice is terribly difficult without a model number of your machine
Mar 06, 2009 | Canon Office Equipment & Supplies
ADF (automatic document feeder) constantly jams
change paper pick-up roller & paper stop roller in ADF
Oct 30, 2008 | Brother MFC-8840D All-In-One Laser Printer
Jams but only w/sheet feeder
Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
Aug 13, 2008 | Sharp AR-507 Copier
Missing pages
Your Doc feed needs new Rollers and Seperation Sheet/Pad, it is pulling pages, but not all the way, while the scanner continues to scan. the ADF might also need adjustment.
Jun 11, 2008 | Sharp AR-M237 Copier
221 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
