Question about Amana SXD524VW Side by Side Refrigerator
Amna cooling problems
The problem started in the refrigerator with the food not staying cool and eventually both the freezer and refrig stopped cooling. There is no heat from the compressor and the evaporator fan is running. It also appears that the compressor is not running very fast.
The model of my refrigerator is a SRD2054W, but it matches the size and looks of the SXD524VW. I would appreciate any help you can give
  • 725 Answers
First it sounds like a relay...
1 check if you have power to relay. ( use a multimeter)
2 check relay if it rattles its broke..
3 check if compresser is runing..
let me know I can help
Posted on Jul 08, 2008
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Refrig side not cooling....freezer side operating fine
Check that the damper vent that sends cold air from the freezer into the fresh food side is not blocked by contents. Check that the damper is opening to allow cool air to transfer. Put the fridge into diagnostic mode to check the thermistors.
Jun 25, 2010 | Maytag MSD2756G Side by Side Refrigerator
Running but not cooling
Pull the refrig out , unplug , and on the back , remove the 8 " X 10 " panel . Behind this panel , is the main control board . On this board , you will see a blue plug ,with 3 larger wires going to it , which you need to unplug .
You will need a short piece of insulated wire , with both ends stripped about 1/4 inch .
Looking at the plug , you will see : wire1 wire2 space wire3 . With the piece of wire , insert 1 end into wire2 , and the other end into wire3 .
Plug the refrig back in . Looking in the freezer section , behind the crisper , after about 1 min , you should see a " red " glow .
If no red glow , this means your defrost heater AND bimetal need to be replaced . Unplug the refrig , remove jumper wire , and plug the blue receptical , back onto the board . Reinstall the panel .
To replace these , remove the food in the freezer , and remove the inside freezer panel ( 4 screws hold this panel on ) , and the heater is below the coils ( 2 screws ) , and the bimetal is clipped on the top of the coils , a 1 " cylinder , with a pink and blue wire going to it .
Part number for the heater WR
Oct 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer has stuck in defront and stops cooling
Yours has a defrost timer board inside the fresh food compartment and behind the control panel. The only way to stop this is by replacing the board. Part number 4388932 and here is a view of its location inside the fresh food compartment. Just be sure the power is unplugged while working with board.
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
KSRG25FK Control Panel
Thanks, Sea Breeze
Aug 17, 2009 | Refrigerators
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Amana SXD524VW Side by Side Refrigerator Logo
152 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
