Question about Bauknecht Dishwashers
My GSX4756 dishwasher seemed to stop mid cycle and the start light is flashing. I have pressed the start button until the light goes out but as soon as I close the door it starts again on the rinse cycle but beeps like it has finished
  • reyton Jun 27, 2008
    Ive already tried this and it didn't work
    Genius:
  • 2,028 Answers
Did you check to see if anything has fallen down into the drain area. Occasionally a butter knife will fall to the bottom of mine where the drain area is, there's an aparature that spins, and stops the machine midcycle.
Posted on Jun 27, 2008
    Sergeant:
  • 275 Answers
If it is a new machine, you can call the suppler or contact the warranty company, if it is not new machine, you need fix it by giving to a hardware technician becuase there is faulty parts in your wasing machine's control board.
  • 6,487 Answers
If your dishwasher fails to complete its cycle, there could be a problem with the timer switch. The timer is what guides the dishwasher thru its various stages.
If the dishwasher stays stuck in one cycle- doing one job continuously- or advances thru a few cycles and then stops, suspect a malfunctioning timer.
Purchase a replacement timer. Remove the front panel of the washer and find the switch. It is usually right behind the control knob. Snap a few digital photos of the wire assembly to simplify installation of the new switch. Simply remove the old switch and replace it with the new one.
Sometimes, a bad heating assembly can cause the washer to not advance past it initial starting point. On dishwashers that preheat the water, there are 2 methods to this. Some use a timer when heating the water, others use a temperature sensor. The ones with with a timer will advance the cycle irregardless of water temperature. If there is a problem with the heating element, then the water won't heat up and the washers with temperature sensors won't advance the cycle.
Hope that helps....
    Genius:
  • 3,422 Answers
try using a pin to poke the tiny holes in the arms that spin round. if they get blocked it will cause it to stop mid cycle
  • Priya darshan Jun 27, 2008
    If that home remedy doesn't fix your problem then the problem can be with two things:
    1)Timer
    2)Control Board.
    These two problems require physical presence of a tech to get it fixed.
    Please don't forget to rate or accept the solution.
    Goodluck..
    Brigadier General:
  • 3,614 Answers
Could be some faulty parts at the control board.. first try to unplug the unit for an hour..
  • 58 Answers
I think.
However, rarely have I encountered an inlet valve that emitted a burning smell. So I'd expect there to be some other problem in there.
But, if the inlet valve didn't pass the test, then it needs to be replaced. Plus, if it was stuck on the rinse cycle and the valve was out, then that is where the cycle would hang up.
Burning smells usually come from a motor, a belt, shorted wiring or a heating element. So if everything else checks out, then go for replacing the valve. The instructions are included in our dishwasher repair section.
  • adham said
    adham said Jun 27, 2008
    Had the same problem. First you will need to tilt dishwasher back 45
    degrees and tip out all excess water. A couple of towels on the floor
    are a good idea.
    Second check that the little nozzle on the elbow under your sink where your overflow attaches is drilled out.
    This fixed my problem after fussing around for a day and I was starting to disconnect everything to take it back.
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Hi Indesit IDL700 Dishwasher. Stopped mid cycle by
The main processor was interuppted and so has hung up or is faulty. Remove the main plug and press on the control pad of the washing machine to drain off any residual voltage that is remaining on the main board and which seems to have hung up the processor.When the plug is plugged in and switch please hold down the start/stop button.
If there is no result after plugging in the machine then the main controller board is a suspect. You can remove the control board and check the connectors, check the main door switch , if possible clean the connectors/ contacts as a last chance.
Sep 05, 2011 | Dishwashers
Clean button won't stop flashing and it won't start, got interrupted mid cycle.
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Feb 05, 2011 | Kenmore 24 in. 17039 Built-in Dishwasher
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Dishwasher won't stop when door is opened mid-cycle
Welcome
You need a new door latch mechanism.
It is faulty and not doing it's job of over riding when the door is opened
Please remember to leave a solved rating before leaving
Dec 19, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Have got a bauknecht dishwasher model no gcx 5521. had the same problem last year. water is not going into the machine it looks like the water stop device activated. I think its something to do with a...
have got a bauknecht gsx4756 which when started beeps continually and start light flashes. it automaticaly then flashes the rinse button as well. I have reset holding down start and mode selection button next to the start button the fault keeps recurring. just wanting to know what the problem is before paying an engineers extortionate call out fees
Jul 31, 2008 | Bauknecht Dishwashers
Blinking clean light
replace the dishwasher thermistor if it didn't work than replace the computer board.
May 09, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Feb 08, 2007 | Bauknecht 24 in. GSFP3988 Built-in...
Dishwashers Logo
402 people viewed this question
Top Bauknecht Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Andrew Taylor
Andrew Taylor
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
