Canon C2100 copier going into a E021 error code and display says drum yellow
    Sniper:
  • 57 Answers
Make sure you have the developers correctly installed ... E021 means you have a rotary error.....
Posted on Jul 10, 2008
E000020-01a2 showing this error
This an error code for the yellow color. The E020 is related to toner or drums. The 01 is for yellow but my book doesn't have the a2 part. How long has it been since the yellow drum has been changed? It's good for about 40,000 prints. Go into service mode and go to copier, display, dens, then misc. This will give you the approximate life of each color drum as expressed as a percentage of life. Hope this helps.
Sep 05, 2012 | Canon imageRUNNER iR C2880 Color Copier
Hi, my canon laserjet printer model Cp660 shows E021 code please how can I fix it. Thanks. Engr. Julius-Nigeria.
The solution is on page 10-34 of the service manual:
http://printer1.blogspot.com/2008/03/canon-cp660-service-manual.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | Canon imageCLASS C2100 Laser Printer
Please I have canon copier IR3170C but it has been giving me this error code E000021 - 0001 any time i on the machine and it is being boot. Please help me out. thanks
getfile.asp?rid=1258 May 8, 2006 getfile.asp?rid=3215 Product : imageRUNNER C3100 / C3170 Title : E021-000x Error Code Error :
E021-000x Error Code: Developing rotary does not rotate and abnormal noise comes from motor.
E021 can be displayed when an error occurs in the developing rotary.
The detail codes are:
0001: The developing rotary home position cannot be detected.
0002: The intervals of flag detection during rotation is too short or long.
0003: The sensor does not detect the flag when the developing rotary stops at development point
As a result of inspection, it was found that the DC Controller PCB was unable to control the motor because it was faulty.
Workaround :
1. Check whether or not the developing rotary receives any physical load.
Rotate the developing rotary in a counterclockwise direction by hand to see whether it rotates smoothly. If any abnormality is found, eliminate the root cause. No problem is found, go to the Step 2.
2. Make sure that the connectors are securely fitted between J313 on the DC Controller PCB and the Rotary Motor (M8) or there is no pinched wire. No problem is found, go to the Step 3.
3. Replace the DC Controller PCB with a new one. If the symptom still recurs, go to the Step 4.
4. Replace the Rotary Motor with a new one.
DC Controller PCB: FG3-3846-030
Rotary Motor: FM2-0080-000 Canon USA, Inc. Systems & Technical Support Division
Jan 20, 2011 | Canon Office Equipment & Supplies
Error code E021
I think that E021 is caused by the rotating unit not rotating or the sensor that detects the rotation is not working. check to make sure that all the colour units are in correctly and not stopping the rotation or maybe something else obstructing it.
Oct 15, 2010 | Canon LBP 2410 Laser Printer
System error e021
In my office this error message E021 came up today,too. So I called customer service to solve this problem.Operator advised me to shut off the power suply with pull out source plug about 5 minutes,after that, put plug in socket again.
If error message E021 still comes up,it needs repair(fix) by cannon support because of breakdown.
gambatte!!(^^)/
Apr 28, 2010 | Canon imageCLASS MF8170C All-In-One Laser...
Canon C2100 I have an error code E677. Can you tell me what the problem is.
This error on your printer is a fault in communication or communication error between the computer and the laser printer. You have to clean every socket or plug of the Printer and you have to also get attention on the internal hardware configuration.
Thank you Sir, Have a nice day.
Sep 23, 2009 | Canon C2100 Laser Printer
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
I am getting a System Error E021, what does this mean?
In my home office this error message came up, E021. I opened the Printer cover, closed it, unplugged and replugged and got a Paper Jam message. I removed the paper jam and did the cover/plug routine. Now I have a message CHECK PRINTER OPEN AND CLOSE COVER. But I can't find anything wrong! I have been searcing for an explanation of the error message online, but haven't found that either. my printer may be infested by aliens.
The best advice I can give is to reseat the various parts (drum and toners).
Thanks
Aug 17, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
Need user manual and/or service manual for Canon imageCLASS C2100
here you go...this printer model is known as cp660 on other regions (based on their Web site).
hope this helps.
Mar 05, 2009 | Canon imageCLASS C2100 Laser Printer
Service Call e021
I believe that is a dirty sensor error message.
E021. Transfer Belt Cleaner Contanct/ Rease Problem.
Cleaner pressure flapper solenoid, Belt cleaner detect sensor, engine PCB.
Feb 23, 2008 | Canon imageCLASS C2100 Laser Printer
388 people viewed this question
jasbo
jasbo
