Question about HP Pavilion dv9000z Notebook
Laptop Video Card/Monitor
Hello, My laptop has recently encountered an error,
When i power the laptop on, the screen just begins to glow from black to to white in no pattern, just random areas. I plugged this into another monitor and got a repeated/pixelated image. I believe the problem is with the nVidia Geforce GO 7600 video card. My question is, would this be repairable.
Id gladly reinstall the drivers, if i could see where the mouse was on the monitor that isnt showing an image.
Posted on Jun 27, 2008
    Genius:
  • 2,028 Answers
Could just be a driver glitch. Uninstall the video drivers from the device manager, then reboot. It will find and reinstall them. If this doesn't work, then replace the video card. Bellow is a link that may help if you want to replace the card on your own, it shows breakdown diagrams for laptops.
http://repair4laptop.org/notebook.html
Laptop dvd/rw has audio but no video
Step 1:
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced.
Feb 15, 2013 | Computers & Internet
My screen is black
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Jan 20, 2013 | HP Compaq Presario CQ50-210US Notebook
Screen wont come on, on my Toshiba laptop computer
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps.
Jan 15, 2013 | Toshiba Computers & Internet
I can't get my laptop screen to come on
Jan 14, 2013 | Samsung Np300v5ai 15.6" Notebook - Intel...
HP laptop screen is black
Jan 08, 2013 | HP VM114UA notebook
Xps M1530 error code 2000-0322
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
Dec 09, 2012 | Dell XPS M1530 Laptop
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
When i turn the notebook on i can see nothing blank black screen
Sounds like one of two issues,
1. You have the internal display turned off. When you turn the laptop on you should hear a single beep. Do you see the Sony Logo during bootup? Have you tried to turn the display back on? Try pressing the Fn+F7, or Fn+F8, key combination. There are only three modes and these key combinations allow you to cycle through these modes. Either the Primary Screen is on, or the External Screen is on, or both are on.
2. You may have a bad video card or the screen is dead. When you power up the laptop, can you see a glow, but the screen is black? Can you see the Bootup Screen with the Sony Logo, but barely? Have you tried to connect an external monitor to the laptop to see if the video card is working? If you get video to the external monitor, the video card is working. If you don't, then the video card may be bad. If you are getting video on the external monitor, try using the key combinations listed above and try to cycle through your Internal/External display modes.If nothing shows up on the laptop display then the LCD screen may be bad. It could be the back light. Those are internal to the LCD. That means you will have to replace the entire LCD display on the laptop.
Hope that helps.
Nov 07, 2010 | Sony VAIO GRZ610 Notebook
After turning laptop on my screen goes black
Bad video card. Laptop probably overheated recently. Plug it in to an external monitor or LCD TV and see if you get video. If not, it's definitely the video card. If you do get video on an external display then the LCD or power inverter is most likely the faulty component,
Jun 24, 2010 | Toshiba Computers & Internet
HP Pavilion dv9000z Notebook Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
