Question about Kenmore 75085 Air Conditioner
Dimensions of Kenmore Window air conditioner 75135
Dimensions of Kenmore window air conditioner 75135
  • Anonymous Mar 30, 2014
    How do I get behind the directional vanes?
    Problem Solver:
  • 17 Answers
Dimensions Width 24 in. Depth 20.09 in. Height 14.41 in.
http://www.dealtime.com/xPF-Kenmore-Kenmore-13-200-12-900-BTU-Multi-Room-Thru-the-Wall-Air-Conditioner
Hope it helps!
Posted on Jun 27, 2008
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    How many BTU is Model#580.74085 580.74124
    8000 BTU. I have one. I'm looking for the EER rating, although I see an energy star label on the front.
    Jun 19, 2011 | Kenmore 75135 Thru-Wall/Window Air...
    I need an installation manual for ac 75135 This is a closeout.
    It is the either the fan bearings is going out of the motor or you just might clean the fan blades it the fan blades has any play on the shaft probably the bearings are going out to the motor.
    Jun 03, 2010 | Kenmore 75101 Wall/Window Air Conditioner
    Dimensions
    by dimensions do you mean the physical size or the capacity in BTUH? you should get a machine that will fit in your window and if the A/C cooled the room ok get one that matches the BTUH output.
    Jun 02, 2010 | Airtemp B3Q06F2A Air Conditioner
    Can i mount my air conditioner on its side its a kenmore model 75135
    Sorry, No. It will not run correctly, drain correctly, or cool probably at all.
    Jun 04, 2009 | Kenmore 73055 Air Conditioner
    Second try....
    Any unit can be recharged, however, its not cost effective to repair most window units unless they are under warranty.
    Sep 06, 2008 | Kenmore 75050 Wall/Window Air Conditioner
    Can a window air conditioner fit in an exhisting wall mount?
    I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
    Good luck.
    Jun 10, 2008 | Frigidaire FAC124 wall/Window Air...
    Through the wall vs. window installation
    I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
    There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
    Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
    Kenmore 75085 Air Conditioner Logo
    1,691 people viewed this question
    Top Kenmore Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Bill Long
    Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
