Question about Aiwa AV-D58 Receiver
Shuts down on it's own
After being on for 3 - 5 minutes, the system will shut down automatically. Will not power back up unless I unplug from power strip and plug back in. But will shut off after 3 - 5 minutes again......HELP!!!!
  • dl76m Jan 09, 2009
    my problem is the same.
    How much does it cost, if i want to renew the solder joints? There are also black "things" on the platine.
    Problem Solver:
  • 17 Answers
You probably have an overheat condition. Get some computer cleaner in the compressed can. Take off the top of the unit. Blow any dust and "the black things" out of the units heat sinks and circuit boards. Happy Listening.
Posted on Aug 14, 2009
I had that, Mine was bad solder joints on the relay. Its on the power supply pcb attached to the transformer. All good now
Posted on Jul 12, 2008
IN104 automatic shutdown
Hello, my infocus in104 will power up for a while (1- 5 minutes) when connected to the power supply and turned on, after that it automatically shuts down. Power button does not light red when it automatically shuts down and need to be unplugged for a minute or more before red power button will light up again.
Mar 21, 2013 | InFocus IN104 Projector
What to do if laptop screen is blank and the lapstop won't shut off
Try to unplug the power cable then flip the laptop over on its closed lid and on the back should be an access to the battery. Remove the battery for about 2 minutes replace the battery and power cable. It should reboot to a black white screen giving 3 choices. You'll have about 35 seconds before the computer auto selects safe mode. Go ahead enter safe mode after it completely boots in safe mode shut down computer completely, wait 30 seconds and hopefully it will start up normally. If it doesn't you may have an issue with the operating system which unless your computer savvy and have all of the computers original cds you'll need to take it to a reputable computer repair shop
Oct 08, 2010 | Computers & Internet
Screen freezes and then shuts off. This cycles every 1-2 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
May 14, 2010 | Toshiba 32HLV66 32 in. LCD TV/DVD Combo
Try the main board with the cpu chip. The cpu chip should have a heatsink attached to it, may be an overheating problem. It has the LCD panel connector plugged into it. You may be able to find the board on ebay for less than a repair shop.
Mar 23, 2010 | Toshiba 32HLV66 32 in. LCD TV/DVD Combo
Pressed hibernation key and now the computer won't work
Unplug the computer for a minute and plug it back in. It should restart normally.
Usually you restart just by tapping a key in sleep or hitting the power in hibernate.
Jul 30, 2009 | HP Multimedia Cordless Keyboard/Mouse...
The Computer has trouble restarting Windows XP. I have to shut it down and unplug it for at least 2 minutes in order for it to start normally past the black screen. Otherwise, it will keep restarting...
I'm guessing from what you are saying, that it will in fact boot to safe mode. the culprit is most likely a resently added program. my other favourite is thermal shut down. remove the cover (after it is shut down and power is removed) and see if it's filled with dust and dirt. when the case is off start the computer up. are all the fans working as well ?
Robert
Aug 27, 2008 | Computers & Internet
Power failure
your laptop may become overheated and that is why it shuts down, make sure the laptop is on a hard service so that the fan can get air. hot weather can cause problems as well.
May 28, 2008 | Toshiba Qosmio G25-AV513 Notebook
Unit shuts off automatically after power on.
You have an internal short in the electrical line. your wall a/c [120 volts] goes inside and is converted [changed] to DC [ like a super battery] There are a lot of connections coming out of this POWER SUPPLY[super battery] to FEED other electrical circuit. ANY one of the circuits can demand more then power supply can give and will cause it to SHUT DOWN [turn off to protect itself]
unless u know what u are doing [" DANGER!! wILL rOBINSON, DANGER!!] you should not mess with it.
Jan 19, 2008 | Toshiba MD13M1 13 in. TV/DVD Combo
Aiwa AV-D58 Receiver Logo
305 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
