Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Where to purchase Power PWB 930B9290001
I was wondering where I could purchase circuit board...
  • 395 Answers
The part number is 930B929001 you have one too many zeros you can get it at
Posted on Jul 16, 2008
I have a Sharp printer Model AL-2040CS (purchased in 2010). This error message flashing "H 4" on my screen.
H4 00 Content Main heater lamp abnormally low
temperature detection
Details The setup temperature (about 90°C) is not
reached within the specified time (about
17sec) from turning on the power ON SW.
(When the temperature of main heater
lamp thermistor falls below 140°C in the
standby mode or printing.)
Whether temperature of main heater lamp
thermistor falls below 50°C in the pre-heat
Cause Main heater lamp thermistor defect
Main heater lamp failure
Main thermostat failure
Control PWB failure
Check and remedy
Check the heater lamp blinking with SIM 52.
When the lamp blinks normally:
Check the thermistor and the harness.
Check the MCU PWB thermistor input
When the lamp does not light:
Check for disconnection of the heater
lamp and thermostat.
Check the interlock switch.
Check the power PWB and the MCU PWB
lamp control circuit.
Clear the display of self-diagnostics with
SIM 14.
Dec 15, 2017 | Sharp Office Equipment & Supplies
What is the full meaning of ptc, mfp, scu, pwb,LSU,LCC,SRAM,SUM,CPT
LSU - Print Head which houses the (LASER)
LCC - Large Capacity Cabinet (Holds a Lot of Paper, more than a normal tray)
SRAM - Static Random-Access Memory
CPT - Toner Cartridge Code
PTC - Primary Transfer Belt Cleaning Unit
MFP - Multi- Function Printer Control Board
SCU - Scanner Unit
PWB - Printed Wire Board (Circuit Board)
Hope that helps
Oct 16, 2015 | SHARP MX-3100N
What is the error code e7-80 on a Sharp ar-m450u ?
E7-80 MFP-SCU PWB communication error
SCU PWB connector connection trouble.
SCU PWB - MFP PWB connection trouble.
SCU PWB mother board connection trouble.
SCU PWB trouble.
MFP PWB trouble.
Mother board trouble.
Check & Remedy
Check connection of the SCU PWB, the MFP PWB,
and the mother board.
Check the ground.
Replace the SCU PWB.
Replace the MFP PWB.
Replace the mother board.
Mar 10, 2015 | Sharp Office Equipment & Supplies
Sharp ar-501 Code H3-00
Heat roller abnormally high
temperThermistor defect
MCU PWB defect
Fusing connector connection failure
Power supply failure
atureCheck the heater lamp blinking
with SIM 5-2.
harness. Check the MCU PWB
thermistor input circuit.
When the lamp lights up instead
of blinking:
Check the lamp control circuit of
the power supply PWB and the
Clear the trouble with SIM 14
Jun 18, 2014 | Sharp AR-5316 Advanced Digital Imager...
Mitsubishi 52525 dlp capacitor problem red light after lamp chang
No the board youre refering to is the Power PWB which is encased inside the metal chassis block. You can get the kit that is for your model that has the capacitors and step by tep instructions on how to disassemble the chassis to accesss the Power Pwb. Heres the link to the kit you need if the lamp led is red.
Jan 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Not the blinking green light problem, but maybe close
its most likely the capacitors on the power PWB which is causing the lamp abnormality. The DM would cause the led to blink continuously. There is a repair kit for the power pwb called the V26 power pwb repair kit available at the following link.
Oct 10, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Hitachi 51UWX20B Projection TV
Hitachi part number JT23051 is Obsolete the new part number for the Deflection Convergence PWB is JT23051R its available from Hitachi for around 350.00
Oct 08, 2008 | Televison & Video
Which board are you refering to as the main circuit board? The power supply PWB ? The Deflection / Convergence PWB ? or the Signal PWB ? respond to this same post and I can help you out, but there isnt a PWB called " main" In that chassis hitachi.
Jul 31, 2008 | Hitachi 46F500 46" Rear Projection...
No DM Board on WD-65833
The Main Board contains the DM circuitry. And you are right, this board does not fail in the way of its predecessors. What is the unit doing?
Apr 30, 2008 | Mitsubishi WD-65833 65" HDTV
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
