Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Computer not recognizing my external hard drive...
Hey,
I've had my external hard drive for a while now and have used it without fail in the past. I grabbed it today to take some stuff off of it and plugged it in and my computer never recognized it. It will not pop up on my desktop like it has in the past. I've unplugged and plugged it back in and turned it off and turned it back on several times with the hopes that it would fix the problem. The only response I've received from the hard drive itself is the blue flashing ring upon power up and then a small flashing red dot periodically. Is the red dot trying to tell me something?
Any Information will be incredibly helpful. Thanks a ton.
--bryan
upton.bryan@gmail.com
  • 3 more comments
  • monteolimpo Jul 10, 2008
    i have the same problem my computer does not recognize de hard drive
  • Anonymous Aug 08, 2008
    I have the same problem confused also must be a internal hardware problem
  • ryoga1843 Aug 16, 2008
    I was using the drive then all of a sudden, my computer would not even see the drive. What's up with this?
  • Anonymous Aug 21, 2008
    I have that same problems. Tried it all using a USB in my camera bag. Then I saw THE cable that came w/ the SimpleTech and now it works well! Check your cable.
  • Anonymous Dec 02, 2008
    Mi pc no reconoce mi disco
    Scholar:
  • 46 Answers
Hi
If all other usb devices work then there's either a problem withthe drive or its drivers. Try plugging it into another computer. Ifthat works on your main computer try going to ControlPanel>>>System>>>Hardware>>>Device Managerand uninstall all universal serial bus controllers, unless you canlocate the one that is for your hard drive. Note: If you have a usbmouse/keyboard this will stop them working untill you select 'scan forhardware changes' at the top, or alternatively unplug then replug them.
Oncethey are all uninstalled plug the hard drive back in and let it gothrough the process of 'found new hardware' etc. This will re-installthe drivers and hopefully solve the problem.
If the drive still doesn't work on eithercomputer then it could mean that it has become corrupted. Right clickon my computer then go to 'manage.' On the left under 'storage' select'removable media' and locate your drive. There should be an option toformat it, BUT THIS WILL WIPE YOUR hard drive! So if you value the dataon it then obviously this is not the best way forward. Another way to format the drive is if you can find it in my computer then you can right click and go to 'format', but again this will wipe the drive.
You could try using a program like pc tools' File Recover to get your files back, though file recovery is a complex process and doesn't always work.
There could be a problem with the cable for your drive - try testing it with another item. Then again if the lights on your drive come on then this may not be a solution worth trying. I think the red light is trying to tell you that something's wrong...
Harddrives do fail - I had to claim on the warranty for my external harddrive a short while ago. It's annoying that the very thing you use tobackup breaks! However, they did send me a replacement in due course, though obviously I lost all my data.
You have to be very careful if you do choose toformat the drive - make sure you format the external and not yourinternal C drive!
Hope this is of some help
Philip
Posted on Jul 16, 2008
Make sure you have the power adapter that came with the unit. That was the problem with mine. Now it works fine.
Posted on Aug 27, 2008
I tried to connect using an USB from my camera bag. I unplugged and restart the laptop. I read an earlier posting about rying another cable. LONG behold, inside my camera bag was another USB cable that came w/ my port drive!!! Now it works beautifully.
Posted on Aug 21, 2008
    Novelist:
  • 167 Answers
I've had this problem before.
I tried a different cord and it started working again. Additionally i've had this work for me (see below)
Try This:
  1. Unplug all USB devices
  2. Turn off Ext Hard drive
  3. Shut down computer
  4. Power on ext hard drive (then wait like 1 min)
  5. Turn on computer
  6. Wait for windows to finish loading
  7. Plug in the USB cord from the ext hard drive to your computer (may take up to a minute for computer to recognize it)
  8. If it doesn't recognize it then keep trying it in different USB ports
If it still won't recognize get all the latest windows update and reboot. If that doesn't solve your issue try your external hard drive on some other computers, check to see if drive needs special drivers installed (which most don't).
From SimpleTech's website: "1) I have the drive plugged in but I cannot find the drive in "My Computer", why?
The most likely cause would be not enough power provided by a single USB port on your computer. Unplug the portable drive from the cable and unplug the cable from the computer. Now, plug the cable into 2 USB ports directly on your computer. (If you have a desktop, you should plug the USB cable directly into the USB ports on the back of the computer. If this is a laptop, you should plug directly into a USB ports on the computer. Do not plug into a USB hub or docking station). Then plug the drive into the cable. In a few seconds you should see the drive listed in the "My Computer" window as a SimpleDrivePS."
If all that fails you need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Two of my Fantom external hard drives do not work. The lights come on, but one makes a clicking sound and the other one no sound. I've checked the power pack and that is not the problem. I don'
Are the drives still under warranty or not? All drives will fail.
If they aren't, break open the case and put the drives into new enclosures or place them in a desktop (if you have extra IDE or SATA connectors available) as secondary drives. You may need adapters if these are portable drives. This will let you see if the enclosure has failed or the drive itself. The one that is clicking may not be usable (clicking usually means a head problem). However, you should be able to recover files. You may need to use a file recovery program, like Recuva, if the drive has lost the partition information.
I hope this helps. If the drives are under warranty, decide if you want to void your warranty. The data will not be recovered under warranty with most external drives.
(I've replaced several hard drives when they went bad. By cloning the drive before it fails, I haven't lost data. I've also attempted to rescue data after the failure. I try to back up important data to optical discs as well as flash drives and backup HDDs.)
Feb 22, 2013 | Fantom Computers & Internet
How to speed up pc applications
If it's almost full and you've been moving stuff to an external, sounds like you really need a bigger hard drive.
You've only got three options:
1) Buy a bigger hard drive
2) Move stuff to the external then delete it off the laptop
3) Delete things off the laptop such as programs you don't use and files .
Make sure you empty your recycle bin, it can hold a lot of junk
May 04, 2012 | Dell Vostro 1700 Notebook
My WD External Hard Drive for Mac will not power up? Is there anything I can do without paying for Data Recovery? I've only had it about 4 months.
you can purchased an external usb case from newegg.com I would first take the hard drive out so you can identify whether you need a SATA to usb hard drive or IDE to usb harddrive. Connect the hard drive in and see if it will power up.
Feb 18, 2012 | Computers & Internet
Repair hard drive hey guys - i've had 2 500gb sata 2.5s fail, one was quite new and working fine externally, i formatted it and installed it on a customer's laptop (she left the charger out during...
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
also you could use a linux operating sytsem 100% free
or you could buy a disk you can get one for around $4.50 "cheap" or download one
http://www.ubuntu.com/download
Ubuntu 10.10 Latest Version
Ubuntu is a linux operating system which can repair hard drives widows have corrupted and cant be repaired by windows operating systems
Hope this helps you
Oct 27, 2011 | Computers & Internet
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
I've been using my windows formatted external hard drive in my macbook pro in the past week and everything was working well. Until today, I was deleting unnecessary files and folders. I encountered an...
Were those files and folders something like System Volume Information, System Restore, Recycle Bin, and Desktop.ini? If yes then these are the folders that store the data about what is in the NTFS partition - deleting them makes the partition unreadable.
To recover your files from it you must install this program in a Windows pc
http://www.softpedia.com/get/System/Back-Up-and-Recovery/EASEUS-Data-Recovery-Wizard-Free-Edition.shtml
and run it. A better but paid program
http://www.easeus.com/datarecoverywizard/recover-formatted-partition.htm
Jun 10, 2011 | Samsung G2 Portable External HX-MU064DC/...
Don't know how to load stuff onto it
You just simply cut the files from your internal drive and paste it to your external drive....
Apr 21, 2009 | Computers & Internet
Hard drive space needed
Simply buying the external hard drive is one thing. Did you simply plug it in, copy stuff over, or _move_ stuff over? You have to move stuff over in one spot to make room elsewhere. Cut-and-paste is your friend. Do not move programs this way -- just data, like videos, music, photos and word processing documents.
There's a wonderful program called ATF-Cleaner from http://www.atribune.org that can also search your computer for unused files. (Windows has a built-in program, too: click Start: Accessories: System Tools: Disk Cleanup). But the ATF-Cleaner is a bit more thorough, does more stuff. You may be simply wasting a surprising amount of hard drive space on stuff like temporary files that became pretty much permanent. You can also free up some space by deleting old System Restore files and the clike -- look through Disk Cleanup.
Dec 07, 2008 | Computers & Internet
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
1,340 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
