Question about LG WD-1280FHD Front Load Washer
Oe comes up on the display
Machine stops midcycle and oe comes up on the display. I think that the drain filter is blocked but I don't know where the drain filter is.
  • 1 more comment
  • tilleyinquex Sep 25, 2008
    Hi, I have the same problem and I've emptied the filter and still no joy - Help!
  • Anonymous Jan 05, 2009
    same problem and emptied washer.help!
  • Anonymous Mar 24, 2009
    Getting OE error code on WM2075CW front loader. Cleaned the drain filter. Restarted a rinse & spin only cycle and still got OE error. Can hear water draining but at a slow rate then machine stops with OE error code. Hoses look ok.
  • 489 Answers
The drain filter is located on the bottom left corner behind the little door.  Remove the door and the filter is located there.
Posted on Jul 23, 2008
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
What does 'OE' display mean after washing circle?
The LG error code OE simply means "the pump is blocked".
A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain.
Sep 12, 2014 | Washing Machines
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
Jan 29, 2009 | Washing Machines
Error code oe
That's not OE, that's DE = Drain Error. Open the access door at the lower left on front of the machine. Use the small hose to drain the remaining water out of the machine, then open the large knob which is attached to the filter. If there is nothing in the filter, you may have an object which made it past the filter and is blocking the pump impeller, or the impeller may have come off the pump motor shaft, which would require pump motor replacement.
Oct 15, 2008 | LG WM-1485FHD Front Load Washer
Lg intellowasher DD 7.5kg WM14225FD error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Oct 01, 2008 | Washing Machines
My lg intellowasher wd1290 error code OE
Sep 21, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WD-1280FHD Front Load Washer Logo
198 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
