The TV keeps going off when we are watching it. It stays on for about 1 second. However, it does have a warm up period, for instance sometimes after turning on it off and us turning it back it will finally remain on.
    Sergeant:
  • 275 Answers
Just check in the menu whether off timer is on or not?....
Posted on Jun 27, 2008
  • 13,433 Answers
Clearly a hardware issue, I recommend you take the tv for repairs.
Theres no simple fix for this over the internet, you can try unpluging the device for few hours and trying again.
Some internal components may need to be replaced.
    Brigadier General:
  • 3,614 Answers
Check the remote control you are using.. better to remove the battery and replace it with a new one...
let me know here again...
TV goes off suddenly. Searching for connection.
'Searching for connection' sounds like it's looking for a network link. check your internet connection. If it's supposed to be watching cable or broadcast TV, check the setup menu.
Oct 21, 2014 | LG 37LH40 37 in. LCD HDTV
Sylvania 6432TD turns off within a second of turning it on
Had same problem Sylvania SRT2232s 32"had to keep powering on and off until it warmed up enough to finally stay on. Problem was the 100/50 & 1/50 filter cap took it to local repair total cost to fix was 74.52 works better than ever
Mar 06, 2010 | Sylvania SRT2232S 32" TV
RCA modelD52W20 Problems turning TV on when it is cold or for the first time after being off for an extended amount of time. The green lite comes on ,stays on a few seconds and goes out. After continueing...
well usually what works for me is a small heater on near the tv or just keeping the room above 65 degrees. There is a way on some tv's to turn off the power saver and that will keep your tv warm. But on others you cant turn it off so you have to deal with the heater or keeping the room warm cause that tv wont turn on for anything exept if its warm....
Dec 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Samsung 50'' Plasma TV won't turn on anymore
If your tv is within the one year warranty period then call 1-800-Samsung for warranty repair. Look at your tv purchase receipt for the Purchase Date. You have one year from the date of purchase to get warranty repair.
Jul 08, 2009 | Televison & Video
Screen periodically going black
try dvd if that doesnt go in and out try a new cable box or ddish receiver
Jun 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Start up problem
chas03,
Your TV chassis no doubt has bad solder connections = chassis
must be pulled, carefully soldered, re-installed..........T.
sholaemman,
You have a source box problem = contact signal provider to reset or refresh set-top box..............T.
Nov 06, 2007 | RCA F32649 32" TV
Televison & Video Logo
Top Televison & Video Experts
