Question about Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
Wait message tried ant and dvd have not tried connecting usb input yet
  • 1 more comment
  • frank z Jun 27, 2008
    the problem is a please wait message when this tv is turned on, i connot go beyond this point with it. i have made sure an antenna input was connected, since this unit has a dvd drive i tried inserting a disc, still have the same message displayed. i cannot get a menu or anything else to display.
    frank z
  • Anonymous Mar 04, 2009
    Do you know the part # for that board?
  • Patrick McGee
    Patrick McGee May 11, 2010
    What exactly is the question/problem???
    All you stated was that you tried ANT & DVD inputs......okay so what is the question???
    Please clarify.
I have a lc26sh10u tv and I cant get all my cable stations.now I know there is some way to program these stations but I dont have a users manual or a remote.also my dvd player is hooked up with rca plugs allows sound but no picture.now I am not completely stupid when it come to how things work.so I can tell the cable issue is a problem with programming the stations.but why google or any one els has not posted basic setup instructions on line is beyond me but I will because spending this much time on somthing like this is not going to happen again if I can help it.CAN ANY ONE HELP ME FOR FREE!
Posted on Apr 19, 2009
I had the identical problem with my Sharp LC26SH10u. It turned out to be a burnt out high voltage transformer (there are eleven of them in my set; one for each backlight) on the inverter board. I bought a new inverter board on E-bay and it took care of that problem. No one on this forum seems to know how to reattach a ribbon cable on the LCD panel itself, though. Good luck with your set and be blessed!!!
Ted Leber
Posted on Jul 08, 2008
Have no picture just keeps say no signal
Check the input jacks in the rear. Each should have a unique label. Pick one input that has cables connected to it. Note the input name. Follow the cables back to the device connected - DVD, BluRay, Cable / Satellite box, etc. Turn on the TV, and select the same input you noted above. Turn on the device connected to it (DVD, BluRay, Cable / Satellite box, etc.). If this fails, try again with a different device or connect the cable / satellite box to the antenna input and select ANT.
May 21, 2014 | Televison & Video
HCP4363W - No color from AV1, AV2 or ANT inputs
You might have a problem with the intenal board or the AV connection onto the board. Have a TV repair center check the board and the connection.
Apr 27, 2012 | Samsung HC-P4363W 43 in. TV/DVD Combo
How to connect an dvd to old tv
they make a small box called an RF modulator. It takes the audio/video signals and turns them into a signal the coax can read. You can pick one up at electronic stores. There usually about 15-25 $.
Feb 02, 2009 | Televison & Video
Help
Hi and welcome to FixYa,
Offhand, the easiest connection method would be to use a short RF patchcord to connect the RF out of the DVD/VCR to the ANT/CABLE/RF IN of the TV. Set the TV to Channel 3. To continue able to receive ant/cable channels, the cable input should go to the ANT/CABLE/RF IN of the VCR/DVD.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Sharp 27R-S50 27" TV
Cannot hook up DVD and VCR to Vizio 37 inch flat panel 2003 model
try connecting the output from the sat reciever into the in ant incoming signal of the vcr use the dvd as one of the inputs to the vcr use remote from vcr to switch from vcr to dvd.
hope this helps
Dec 28, 2008 | Vizio L37 Television
What kind of cords do you need to hook-up to a tv??
Offhand, the A/V cable would be readily available from most electronics supply store, Audio/Video/TV stores, MP3 and even computer shops/stores. The cable would be as shown below:
Alternately, you can connect the RF OUT of a VCR to this RF/ANT/Cable IN of the TV, set the TV to Channel 3. An RG59 patch cable would do the job. Should you want to connect a DVD, connect the Video/Audio OUTPUT of the DVD to the Video/Audio INPUT of the VCR. Incidentally, the regular cable/ant should be connected to the RF IN of the VCR.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 13, 2008 | Philips DVP3345V/17 DVD Player/VCR
VCR/DVD
Initially, it would appear that the only INPUT possible is through the RF connector. Should this be the case, a workaround would be to connect the RF OUT of a VCR to this RF/ANT/Cable IN of the TV, set the TV to Channel 3. An RG59 patch cable would do the job. Should you want to connect a DVD, connect the Video/Audio OUTPUT of the DVD to the Video/Audio INPUT of the VCR. Incidentally, the regular cable/ant should be connected to the RF IN of the VCR.
Dec 12, 2008 | Emerson TC1325 13" TV
No Signal
I connected the cable to Ant-A, then connected a short cable from the out loop to Ant-B. Works fine. Didn't have a manual, had no idea.
Sep 05, 2008 | Mitsubishi WS-55807 TV
Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo Logo
166 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
