Question about Vacuums
Belts on Sebo Automatic XP1 - Vacuums
  • dittons Jun 28, 2008
    Thanks, I've got into the machine by following your advice.
    Now, how does one get the belts off and the replacements on? It seems as if half the machine has to be undone!
    I have contacted Sebo; they do supply parts to the man in the street. Their number is (For United Kingdom) 01494 465533.
    Problem Solver:
  • 17 Answers
I am not sure of the question about the belts. This is information I have found and maybe I will answer your question.
This link is a parts breakdown of your machine.
http://sebo.com.au/downloads/9547AU_9548AU_9549AU_1.pdf
Reference # followed by part # then description.
153 - 5463 Belt 2MR-310-6
154 - 5110 Belt 219 3M-HTDII-6
The following link is to contact Sebo, If you need to order belts, they may sell directly to you so contact them and give them the part #'s I supplied. If they wont sell directly to you, they should give you information on who around you is a Sebo dealer and will have belts to sell you.
http://sebo.com.au/component/option,com_facileforms/Itemid,29/
Hope this helps, please post back.
Posted on Jun 27, 2008
  • D B Jun 30, 2008
    I have changed many belts on many machines, however your model of Sebo I have not. But from looking at the breakdown and from what I have come across on vacuums, they will always have some extra space incase the belt expands so it does not hit the cover. So I would not think you would have to take much apart to change the belts. I would suggest taking the main bag housing off, a release latch is on the front of the bag housing on the bottom in the middle (In the break down they refer this as "Housing Release Button" Ref #8 On page 4. Then you should be able to remove the top cover all the way off to expose the belts, you may be limited on space but you should be able to turn the belt sideways to get it on the pulley. Put the belt on the hardest to reach pulley first, then attach the belt on the other pulley. Some machines do limit you on space, but it should have enough. If you have further questions, Sebo may have instructions they can e-mail to you on how to change the belts. If they do not, I can look into it more. Good luck!
Hi. I have a Sebo X1 about 12 years old. Last time I used it there was an unpleasant smell in the room but didn't seem to be coming from the Sebo. However I am now trying to use it and it doesn't work. The...
The unpleasant smell could have been the lifetime belt finally giving up. Also happened on our 13 year SEBO X1 Automatic due to my error of vacuuming up a rug with long loose strands! If you are good with a screwdriver, you can replace the drive belt easily enough - go onto You Tube - there is an excellent UK video showing how to replace the drive belt on the SEBO. There are two belts, but you will know which one has to be replaced if you remove the screws on the underside of the main floor head. Before you do anything, kneel on the floor beside the SEBO and press the main release button on the bottom of the front bin area just above the floor head. It may need brute force but when pressed, put on knee on the floor head gently and pull the bin upwards to release from the body of the SEBO. This unlocks the main floor head from the bin, making it easier to look at the floor head. See video: http://www.youtube.com/watch?v=AOPphVcZHYA
Sep 14, 2013 | Sebo Vacuums
Automatic height adjustment not working
Check that there is no dirt clogging the main central wheel on the underside of the floor head. In any eventuality the main floor head hood will have to come off, via screws on the floor head base. By the right hand side , if looking down into the internals you'll notice two drive belts - check and see if these are intact. Directly next to this is the LED microchip board. Check that all the microchips are pushed in, as there is one for the height control that can usually pop out if the SEBO has been dropped or if the machine has been bumped off walls.
Aug 21, 2013 | Sebo X4 Bagged Upright Vacuum
Height adjustment not working.
It's likely the circuit board that controls the height adjustment motor, or the motor itself. Your local sebo service center will be better able to test to see just what is wrong. Though it wouldn't hurt to take a look at the boards sometimes they're visibly burnt, or connections can be loose. Good Luck!
Feb 16, 2013 | Sebo Automatic X1 Bagged Upright Vacuum
Our Sebo Automatic x1 will now only pick up with nozzle. Hight adjustment doesn't seem to operate and no green lights display. No blockage found, roller works okay. Help! Wife becoming v. angry.
The belt on the motor shaft is probably slipping off. I have the same problem and that's what I saw when I opened the vacuum. I keep putting the belt back, but it slips off again. The belts aren't supposed to stretch. I am going to call Sebo and take mine to an authorized service place to make sure that it is just a stretched belt.
Jul 10, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Trying to replace the belts, cannot get the large belt on
Hi Danny,
Copy and paste this address from our website: >>>> http://www.fixya.com/support/t2681489-sebo_automatic_x1_cleaner_toothed_belt
One of our experts gives a full description of how to change belts and what to be careful of when you do.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
May 20, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
How to change belt on sebo the big drivebelt
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment. (This is the policy of Sebo America, if you're in the UK please check Sebo UK"s policy).
If you have any further questions on how to replace the belt, please feel free to reply to this repair by leaving your question in the comment section, I'm always more then happy to answer any question you may have.
Thanks again,
Chris Jones
goVacuum.com
Aug 09, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Hi, My Sebo X1 has a problem... The brush has stopped rotating (just after a noise like a jet engine!). Is this a belt problem? What's the best way for me to check. Thanks, MP
It's possible you have a broken belt, although Sebo belts usually last at least 10 years and often much longer. The first (and easiest) thing to do is remove the brush roll and check that it's not damaged where it mounts on the metal drive spindle. If that's OK, place the machine in a position where you can see the drive spindle then, keeping fingers and clothing well clear, switch on and check if the drive spindle rotates. If a belt is broken, the spindle will (of course) not rotate. The ultimate check is to take the cover off and have a look. To do that, first separate the bag compartment from the base, then turn the base upside down and undo the four deeply-recessed screws. Turn the base over, move the suction tubes out of vertical and just lift the cover off. The belts will be exposed and all will become clear (or possibly not!).
If you need guidance on changing belts, you can search on this site, as it's a question I've answered many times here. If you still have a problem, post a reply here and I'll see what more I can do to help. Good luck!
Jun 02, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo automatic X1. After switching on the motor
As sure as possible without actually seeing your machine, the carbon brushes on the motor are worn out. They are quite easy to replace (and not expensive). If you need help with doing the job, just post a reply here and I'll guide you as best I can. If you choose to have a professional do it for you, it should take no more than half an hour's labour.
I hope this has been helpful - please remember to score me! Good luck!
Feb 10, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
I need to know how to repalce the drive belt in a Sebo upright cl
Thanks to its automatic height-adjust feature, the Sebo X4 has two drive belts, one from the motor to the height-adjust sensor, and another from that sensor to the brush roller. To access them,first remove the base from the handle, undo the four recessed screws on the underside of the base, then turn it over and lift off the cover. You will then see the belts. The rest should be obvious (it's a while since I've done one of these, but I think you may have to loosen the screws holding the height-adjust sensor before you can slip the belt off).
I hope this helps. Any further problem, just re-post here and I'll do my best. Good luck!
Feb 01, 2009 | Sebo Air belt K3 Bagged Canister Vacuum
Windsor sensor sr12
There is a downloadable manual from http://www.windsorind.com/ go to documents, and note it is in alphabetical order -- so page through to "sensor" or you can search on the word "sensor" (don't include SR12). Also excellent training video on youtube http://www.youtube.com/watch?v=ikhtNFEKpeg.
I think, but not validated yet, that the Sensor SR12 (residential model) has been discontinued as I found it listed in their manuals under the discontinued section as well.
Jan 28, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
Vacuums Logo
93 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
