Question about Rolex Explorer II 16570 Wrist Watch
How to remove links if there are no pins
I just received a watch for my graduation, but there are no pins, so I don't really know how to shorten the band.
I was wondering if anyone can help with that. Thanks!
  • 2,334 Answers
All Rolex watch bracelets has screws, not pins. Get small screwdriver and unscrew them.
If there is no screws at all, that means bracelet links had been removed and you have shortest version allready ,or, this is not the real (genuine) Rolex bracelet.
Find your nearest watchmaker to clarify all this.
Posted on Dec 18, 2008
Wrist watch shortening
Look at the inside of the band and there will arrows pointing what direction the to tap the pins out to remove links. Put the watch on a small roll of tape or something similar that keeps the band off the surface you are working on. Gently tap the pin out with a tool that will fit in the pin hole. Remove the pin and determine the number of links to remove. Remove the links and reverse the order in which you took it apart .
Apr 27, 2014 | Citizen Eco-Drive BL006056H Wrist Watch
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
How do I take out a couple links in the band of a 7056 White Peugeot watch. The pins are not spring loaded like most other watches. The band is plastic and there is only one pin per link. I don't know if...
Hi I just bought this watch for my wife's birthday and we had the same problem, it was too big. I googled and binged for a solution to shortening the band or to remove a link but no one had an answer. I go crazy with things like these and just decided to look at the watch band. First took out the pin for the latch so I can get a better look because that pin can be pressed down. On the inside of the band are arrows. Those arrows indicate which direction the pins can be pushed out. Just push the pin out with a tool, they will require a little pressure but they will give because one end of the pin is bigger than the other. Remove link and enjoy. Hope this helps someone else out there. Just a note this is only for the Peugot 7056 it has a white plastic band and I wouldn't recommend anyone try this with any other model as I don't know how those bands are designed.
Dec 30, 2010 | Peugeot Watches
Shorten the band on a Mossimo watch
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    How do I shorten my Ice watch strap?
    mcdevito75 here, I imagine you mean a Band (metal) they can be shortened by removeing links from the band itself, you"ll need a specific tool called a link remover tool. they are available on ebay. However by the time you get the tool and the time to do the work, and if you don"t do any work on watches, the best bet is to look for a small watch repair shop in your area to remove these links. Hold onto the removed links for later replacement. If it"s a Strap (material) on your watch, say, leather, rubber etc. simply cut the excess strap at an angle with scissors.
    Jul 17, 2010 | Watches
    I want to remove links on my wristband.
    Most wristband links are held together with screws or pins. Screws are usually only found only in high end watches so you most likely will have to remove pins. Without the proper tools and know how you will most likely scratch the bracelet or, worse, damage the pins. A jeweler can do this for you easily and, if they even bother to charge you, it shouldn't be more than $5. Should you wish to proceed on your own, you can buy the specialized tools on ebay quite reasonably.
    Apr 10, 2010 | Armitron Two Tone Sports Watch
    Shorten watchband
    I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
    Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
    It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
    Mar 30, 2007 | Timex Outdoor Casual Expedition®...
    Rolex Explorer II 16570 Wrist Watch Logo
    1,108 people viewed this question
    Top Rolex Watches Experts
    Samyfam
    Samyfam
    Are you a Rolex Watch Expert? Answer questions, earn points and help others
