Question about Sharp XR-10X Multimedia Projector
Remote Everything with the remote works well except its ability to move the slides forward/backward. Any suggestions?
  • 115 Answers
Have you connected the USB Cable with computer to opearte mouse?
Viren
Posted on Jul 17, 2008
2002DodgeRam1500 quad cab,when I drive in reverse,to park,when I hit the brakes a noise comes out like an old drum brake ,except mine are disc brakes.The pads are thick and even.Any ideas
well if your brakes are working well i would ignore it but if brakes don't work well i would take pads off the rear brakes and lubricate the slides and also put some behind the pad plate where the piston touch's the pad!! when u put brakes on going forward the pads slightly move forward and then when you go backwards it moves even more and i think thats what causing it!
Mar 25, 2013 | Cars & Trucks
860 slide projector does not move carosil forward or backward and does not respond to selecting slides, but manual on projector will actuate slides but will not move carosel forward or backward. thanks
there is a small rubber link inside the projector that controls the advance this part fails in time and would cause this problem. the part is not hard to recreate but is difficult to replace.
Jan 16, 2011 | Office Equipment & Supplies
Everything works on the power seats except unable to move seats forward and backward
There are usually 3 motors for power seats, 1 to tilt the seat, 1 to raise and lower the seat, and 1 to move the seat back and forth. I would think that motor is bad. Check for any obstuctions to the seat track.
May 06, 2010 | 2005 Chevrolet Trailblazer Ext
How do i advance my slides with the remote?
I HAVE THE SAME DUMB PROBLEM!! Everything works EXEPT moving the slides forward! Anyone have a solution????
Jul 08, 2009 | Epson (V12H007T06) Remote Control
Broken power seat - cannot slide backward. Can I slide it manually?
Ck for debri or other objwcts in way of tracks Does it try to move? If so, there is an obstruction, If not trying or no sound when switch is moved, could very well be a fuse or the forward limit switch is being affected by excess forward travel. Move the switch yo back and without kinda help it. if it's trying.
May 17, 2009 | 1992 Toyota Camry V6
Everything works except for ther forward and backward rotation mechanism. When these buttons are pressed there is a buzzing sound perhap indication a motor problem?
This is a very common problem with these old Kodak projectors and is caused by a small part called the solenoid link that can be purchased separately or as part of this kit: https://www.micro-tools.com/store/item_detail.aspx?ItemCode=KODAK-KIT
There is also a guy on eBay, "atomk", who sells kits with very clear instructions on how to repair this problem yourself. Search for "Kodak Carousel Projector ADVANCE Repair Kit".
May 03, 2009 | Office Equipment & Supplies
The lever to move the driver's seat forward and backward doesn't
The reason is that your sliding grips have been slipped and therefore jammed at one position.
Remove the seat open it's sliding grips and replace it.
Jan 28, 2009 | 2002 Nissan Pathfinder
How to Use remote to forward slides of PP presentation
Hi Carolyn
You'll see that the Projector came with a USB cable. The USB cable should be connected from your PC to your Projector and this will enable you to flick through your slides with the normal BenQ remote control.
Thanks for using Fixya !
May 06, 2008 | BenQ PB6100 Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
113 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
