Question about Samsung Office Equipment & Supplies
Cant get paper to feed on samsung clx 2160n - Samsung Office Equipment & Supplies
  • tmarps Feb 26, 2009
    Same problem, just won't pick up the paper from the paper tray. Constantly getting paper jam errors.
    Master:
  • 377 Answers
Most such printing problems stem from incorrect paper types or paper loading. Make sure that your paper is loaded properly, and that the paper type is made for your specific printer.
Check the hardware.
If paper is not feeding properly into the printer, the problem may stem from hardware failure. Check the feed assembly to see if all the parts are in working order. You may be able to manually advance the paper in order to see which component may be failing. If necessary, clean the paper pickup rollers to make sure the paper path is free of sticky dirt and debris.
Posted on Jun 27, 2008
Paper feeder keeeps jamming
The paper feed roller probally needs to be cleaned or replaced. It is located in the back just above the paper tray. Try cleaning it with a damp cloth to see if that makes it work better.
Jan 01, 2011 | Samsung CLX-2160N All-In-One Printer
Non-working printer; no paper pickup
The solution shown for the Samsung CLX-3160FN All-In-One works also for the Samsung CLX-2160N.
The associated picture and methodology of "pre-stretching" the solenoid spring is virtually identical for both printers.
Worked for me on the CLX-2160N
See here
http://www.fixya.com/support/t4742967-deve_home_sensor_error
Jul 07, 2010 | Samsung CLX-2160N All-In-One Printer
Constant paper jams (paper does not feed through)
The problem is probally the feed rollers are either dirty or worn. If they are dirty they can be cleaned with a damp soft cloth or a foam brush. Hope this helps.
Jul 03, 2010 | Samsung CLX-2160N All-In-One Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
CLX-2160N Paper Jam?
my printer Samsung CLX-2160 give me the message "paper jam", but I checked a lot of times inside and there is no paper. What's the real problem? How can I solve?
Mar 04, 2009 | Samsung CLX-2160N All-In-One Printer
Samsung CLX-2160N Sanner Locked
Same problem thanks for ignoring guys!
Dec 11, 2007 | Samsung CLX-2160N All-In-One Printer
320 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
