Question about JVC AV-48P775 48" HDTV
Volume wont work
My T.V. wont put out sound, but the display shows it moving up and down. And in the sound menu The Bass, treble, and balance show zeros. and these options are inaccessable. Do I need a repair man?
  • 42 Answers
In the menu for initial setup look for a setting for center channel and turn it off. If it is on you will have no sound because it turns the TV speaker into the center speaker for a surrond sound receiver input.
Posted on Jun 27, 2008
I am suddenly unable to adjust the base, treble, volume, etc on my Alpine CDA-7940 stereo. Is there a lock or setting for this?
press the mode button, which is the audio knob repeatedly to choose the desired mode and rotate the knob until desired sound is obtained. as you press the mode button, the option will go from these followings: volume, bass, treble, balance, fade
Jan 13, 2015 | Alpine CDA-7940
What are good settings to have to make the music sound clear for a jvc KD-R310 deck?
you will need to access the bass and treble setting on the unit.
If you have stnadard speaker then dont put the bass to high as you can not turn the volume up high.
The same for the treble.
Set them at about the same and turn the volume up until it sounds good.
If it is to quiet then turn the treble and bass down and then the volume up more
Mar 02, 2011 | JVC AM FM CD DET FACE CAR STEREO
Jvc hd-61Z786 REAR PROJECTION TV . is dark. replaced the lamp. did not help much
all u have to do is to
Reset Picture and Sound Adjustments
1.Press the "Menu" button.
2. Press the "CH+" or "CH-" button to "Reset" listed on the display.
3. Press the "Volume+" or "Volume-" buttons to move left or right to enter your Reset selection. The Reset will reset all of your picture adjustments, including the color, brightness and tint to the default settings. Reset also resets your sound adjustments to the default settings, like the balance, bass and treble.
4. Press the "Menu" button to complete the resetting process
Feb 23, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
How to turn sound on phillips plasma 32 inch tv
Hello
I thinks that you want to tune your TVs sound parameters, and answers. As you know, when the TV is switched on it will display picture as well as sound, according to the volume level setting. If you want the qulality of sound much more better, by pressing Menu button and higlight the opton 'Sound'. As you select, there will be a 'tick' mark appears, indicating that sound option is selected. On to the right side, there will be Bass, Treble,and balance control displays. Use "Cursor Up" button to go box 'Bass", and increse or decrese Bass lavel as you likes. If you wants to adjust treble, use "Curser Right" button and do as previous to your taste. Come to the "Balance" option by using "Cursor Up or Dn' keys and set it to mid position. There will be indication for its mid position, and it should be in that position, so that you can hear sound from both speakers equally.
All jumpings and adjustments can be done with 'CursorUp, CurserDn, CursorLeft, CurserRight' Ok.
Oct 31, 2010 | Philips 32PT6441/37 32" TV
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
The stereo comes on, switches modes, tunes up and down, volume meter moves up and down, bass,treble, balance all work but no sound at all.Any answer?
you might have a built in amplifier that was from factory i would start there if the head unit is bad and well need to be replace
May 06, 2010 | 2000 Chevrolet Impala
Adjust
I have an Alpine CDA-9813 and to access bass, treble, fade, and balance, you need to press the volume button. This button is usually rotated to adjust the volume but on mine, if you press it in, first time accesses bass, second press accesses treble, 3rd press accesses balance(left to right), and 4th press accesses fading (forward to rear. Press it a 5th time and it either brings you back to volume or back to the main screen. I think it is volume tho. I would assume that the 9853 would work very similar, if not the same.
Mar 21, 2009 | Alpine CDA-9853 CD Player
I need to find out what buttons control the bass and treble
Press in on the volume control repeatedly to step through the menu of audio functions. The
first option is Volume, followed by subwoofer (only if the subwoofer feature is currently
activated), Bass, Treble, Balance, Fader and back to Volume. When adjusting audio functions,
the unit will automatically exit audio control mode after five seconds of inactivity
If you need the user's guide, click her to download.
Feb 21, 2009 | Jensen MP7610 CD Player
How to adjust treble and bass
At the lower left of the unit, just right of the power button is a button marked LD, with A-M below that. Push this button and the display will say BATT, then, in a couple seconds it will display 2 numbers. The left number is the bass and can be adjusted with the select arrows (left & right arrows). The right number is the treble and can be adjusted with the volume arrows (up & down arrows). If you push the LD button once more, it will display BAL, then 2 numbers. The left is the left-right balance & the right is the front-back balance. They can be adjusted in the same way with the arrow keys. Hope this helps someone.
Jun 11, 2008 | Clarion RDB325D
Controls
Press and hold the menu button (either on the remote or the display itself). Other forums have said you only have to hold it down for 10 seconds, but that isn't accurate. I had to hold my menu down for about 30-45 seconds to unlock the OSD.
Aug 25, 2007 | Dell W1700 17 in. HD-Ready LCD Television
JVC AV-48P775 48" HDTV Logo
130 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
