Question about HP Deskjet F340 All-In-One Printer
POWER SUPPLY NEED REPLACEMENT POWER CORD
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Www.hp.com may be the only place to find that..
Posted on Aug 19, 2008
I need to find a replacement power cord for this tv, any suggestions? I can't find it
you don't say what has happened to existing cord or what is wrong with cord. Have you tried to get a replacement cord at a tv repair shop?
Nov 24, 2012 | Televison & Video
Power supply was cut
you can buy a new power cord or you can use another wire to replace the cord. just buy the same size then you will need to remove the rear cover to access the internal. and then the old cord must be removed from the ac terminal pin and the assembled wire with plug that you buy can be replaced. you can directly re soldered the end of the ac wire at the pcb for ac supply.
Aug 16, 2012 | Mitsubishi WD-57732 Projection Television
I need a new power supply cord for my Cafe Collection electric skillet Model SY-101K or LPH-5
try an appliance repair shop as most have replacement cords for most appliances
contact the manufacturer on line in their spare part section and order one
Jan 23, 2012 | Wolfgang Puck Kitchen Appliances - Others
Tower won't turn on. There is a green light on the back near the power cord that's flashing green.
Pull the power cord out and allow it to reset. If you still have issues you may need to replace your power supply.
Aug 05, 2010 | HP Compaq Presario Media Center SR1750NX...
The power supply cord does not charge or supply power to the laptop. I purchased a new power cord only to find out that it is an internal issue. What part do I need to replace the internal power supply?
in all likelyhood it's the connect that the power cord plugs into. the soldering often fails in that area. it needs to be resoldered to make a good connection
Mar 28, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
Power cord connection issue---we have tried different power cords. Issue is where it connect to set. The power will come on, but the set will shut off
This failure might not be in the power cord but the internal power supply. If your LCD is older then 15-18 months for sure it needs a power supply replacement.
Symptons of a failing power supply are:
1- Set does not powers ON.
2- Turns OFF by itself.
3- Needs to be unplug to make it powers ON again.
4- When the set is ON, it produces a humming noise through the speakers.
You can find a power supply replacement visiting this website and you should be able to replace it yourself.
Oct 17, 2009 | ViewSonic N3250W Television
Need replacement power supply cord for the Janome 6600P sewing machine
I need a replacement power supply cord for my Janome Memory Craft 5700. Can anybody help?
Mar 02, 2009 | Sewing Machines
T5026 won't start up
Unplug the power cord, open the computer and disconnect all the power cables (the cables going from the power supply to motherboard and drives). Then reconnect the power cord and see if the light on the PSU comes on, if so disconnect the power cord and plug in the motherboard connectors and continue connecting components one by one to determine which may be the problem. If no power light with everything disconnected then the PSU needs replaced.
Jan 03, 2009 | E-Machines Emachine T5026 power supply **...
Power Suply Cord
If the cord is the ONLY item you need and NOT the terminal block in the dryer, then Home Depot sells replacement cords with a molded plug attached as well as ring lugs on the opposite end for terminating them on the dryer block. You'll need to know if you are using a 3-prong or 4- prong set up in order to get the correct cord. Hope this helps..
Sep 06, 2008 | Whirlpool LER3624JQ Electric Dryer
27 people viewed this question
Seeker5211
Seeker5211
